1 - 9 of 9 Posts
does anyone know if i could run either the 177r or the 137r component set in kick panels and then add an 8" diy for midbass in my doors with the stock crossover and a p860mp head unit?
run the 8" off the stock crossover of the Type-X components?
-OR-
run the Type-X components off the stock components, then run the 8" off a separate channel, active..?
if you can fit the eights getm. got power?
had those and while I like the tweet very much (not as much top end for me personally-ie the lpg's are more detailed and sparkle more to my ears--others may differ)
but id bet youd get better midrange out of the dayton 7" over that vifa pulp driver in the 177r set
the crossover is awesome though
i wouldnt be so quick to say that... the vifa xt have great midrange
masse1369 said:
im saying run the components just as is and then add an 8" midbass and run it off the headunit x-over.
Yes, you can definitely do that!
I was planning something very similar, until i decided to go full active.
With the Type-X passive xovers you can adjust/tune different slopes and xover points so they can perform more optimally to your application too.
I would use the 5.25 components in the kicks, so i wouldnt have to use as much footspace.
^try to keep the mid and tweet together so they wont need any time alignment inbetween them too..
1 - 9 of 9 Posts
