1 - 3 of 3 Posts
SSA XCON 15D2
7/10 looks due to foam on cone, 10/10 mechanical
I used this driver for less than 6 months. I accidentally got expanding foam on the cone. It has not affected performance at all. There was a slight tear in the surround that did not go all the way through that I repaired with amazing goop.
I removed the expanding foam in a few spots. It is removable but use caution, it does pull a small amount of the surround off.
$240 shipped OBO
UPS Lower 48 only
Introducing the XCON, the new pinnacle of sound and output. With a brutally strong single slug motor that has a monstrously bumped back plate, the XCON really sets itself apart from the pack right away. We started with the ideals behind the ICON and went to the ultimate degree with the XCON. With an eye popping 31mm of excursion, the XCON uses a 3" roun.6d, 2.6" long, 4 layer Aluminum voice coil, that strong enough handle some serious levels of power, yet is light enough to still be very accurate and precise. To keep the inductance in check, the XCON employs an Aluminum shorting ring. For those high power installs, the XCON runs 5 spiders in total: triple 8" progressive spiders, dual NOMEX spiders and triple flat sandwiched lead wires to handle all the abuse.
For seriously high output installs and sound quality competitors alike, the XCON is at the top of the food chain. With output that has been described as being hit by a sledgehammer and pin point accuracy, the XCON has all the bases covered. You can be proud of your purchase, because the XCON is designed and hand crafted in the U.S.A. The purpose of the XCON is not to match or just beat out the competition, but to make sure there never was competition to start with. There is only one choice in the super sub woofer market and you are looking at it.
3"” wide, 4 layer, Aluminum coils
Built in Cooling option
Push terminals
Pulp Fiber Cone
5 progressive spiders
Custom FEA optimized motor
Aluminum Shorting Ring
3" Anodized alum. former
Triple Sandwiched Leads
Hand crafted in USA
1750 rms
Enclosure Recommendations:
Sealed: 2.0 - 2.25 cu.ft.
Sealed: 2.75 - 3.0 cu.ft. optimal
Ported: 3.0 - 3.25 cu.ft. @ 26-33 hz
Ported: 4.0 cu.ft. @ 26-33hz opt.
Sub Outside Dia.: 15.625”
Cut Inside Dia.: 14.125”
Displacement: 0.20 cu.ft.
1 - 3 of 3 Posts
