1 - 8 of 8 Posts
2019 Subaru WRX Base 6-speed
So a friend let me use his SMD DD-1 to determine where my stock head unit starts to clip. It's a 2022 WRX Premium and with a 40 hz tone at 29 the clipping indicator flashes ( at 28 it flashes once only ). With a 1khz tone it does not detect clipping even at full volume. Is this normal? I assume 28 would need to be my max volume level so I can set my input gain on my V Eight that I'm using to integrate with. Side note: I will be using LGD-20 from Audio Control so I wont get an error from my StarLink module for not detecting a speaker connected to it, should I re-test after the LGD?
Yes retest after the LGD-20 is connected, then take the average clipping of 40Hz and 1K Hz. What is he max volume level of your headunit?
Vendor
Yes this is normal in most modern cars. use 28 as your max volume.
No need for them. If you have a Helix V Eight Mk2, it has ADEP.3 built in. It is a smart circuit that detects OEM load requirements and applies the necessary load.
Reactions: THX0849
Discussion Starter · #8 ·
Thanks Nick, wasn't sure the V Eight would have the right circuitry or not. That'll save a little bit of work at least. I'll be using 28 as my max point, thanks!
1 - 8 of 8 Posts
