1 - 16 of 16 Posts
· Registered
OK, I don't mean to beat the old dead horse here. I know this thread has probably been created a bunch of times, I've read most of them.
The application - corner loaded enclosures, 7" depth, 7" magnet diameter, 11" cutout, 12.5" O.D MAX
Amp - Hopefully I only need10 total watts from a zuki eleets (I could use my DLS A6 or a zuki small mono eventually)
Goals - I want accurate bass reproduction that will integrate well with my Midbasses. I do like it loud sometimes. I currently have 2 eD 13Ov.2's. I'm probably going to get 2 subs, but if there is 1 sub that do the job better than 2 of the others I'd consider it...
If there is a sub that would only fit mounted inverted, I'd consider only if it'd be that much better than the others...
Current Contenders, all should fit, and all have a voice coil config that will work for me:
Zuki 12" subs
Diyma R12
Fi Q 12"
Stereo Integrity Mag V4 12"
SSA DCON or ICON 12"
Dayton
I'm also open to other suggestions.. Let me know your opinions on these!
(Tspence need not reply)
· Premium Member
Your A6 matched with the diamond D9 im selling sounds like a perfect match
I would have to agree, the diamond is among the quietest during full excursion of any sub I have ever heard. I am talking mechanical noise not how loud the sub is, those subs are way to overlooked
· I'm baaaack!!
Yes, a DIYMA mounted ass out is a thing of beauty. :D
That being said, I have personally run both the DIYMA and the Mag off the back half of an ELEETS 4 channel. That amp can drive either one of those subs beautifully. What are your plans for 2 subs though? Were you expecting to run both of them off the back half of your ELEETS or are you going to use the DLS A6? I do know that both subs do just fine off of 300 watts each. IMHO, if you want to do a standard mount go with the Mag. If you want to invert mount your subs then use the DIYMA. Either way you'll have great sounding subs in your car. And while I can't speak for dual Mags in a car (though I'd be scared to think of how much output that would be) I can say that dual DIYMA's in a car can get silly loud.
Zach
· Registered
Discussion Starter · #15 ·
I installed the first zuki today, and I'm positive that my subs will be run off of 2 channels of a zuki.
So I'm still torn. The DIYMA's might be out, I have to figure out if they'll even fit without inverting them, that would help my decision.
I need like a side view w/ dimensions so I can make a cardboard cutout and see what it looks like in the box.
· I'm baaaack!!
I can tell you that the DIYMA has a MASSIVE motor on it. Yes the sub is only like 6.5"-7" deep IIRC, but that magnet is just over 9" in diameter. It's HUGE!! If you need a "small" framed sub that sounds just as good as the DIYMA then look at the Mag. Have I steered you wrong yet? LOL!!
1 - 16 of 16 Posts
