1 - 8 of 8 Posts
Hey everyone, I need a little bit of advice on getting a bit sub output in my car. i have a 2013 crv with cdt es components (es-02, es-06) up front and i have 2 illusion audio c12 in a custom box in the rear. helix dsp.3 and audison voce 5.1k for processing and amp. i cannot quite get the output and depth i am looking for and would like to upgrade or go for a lateral choice. I am thinking the sound is limited by having shallow mount subs. What are your recommendations?
Budget: Single sub- under 600
dual sub- under 900
Thanks you all.
261973
Pic is my work in Progress.
Have you used a mic and run an RTA to see what's going on? A pair of 10's should do pretty well in a hatchback. Those illusions aren't exactly true shallow mount subs, with the motor up front they retain a pretty decent amount of excursion that most shallow mounts don't have. Before ditching some great subs I'd spend some time with a mic, and your DSP to see what's going on.
Thanks for the suggestions guys. I just adjusted the crossover point for my mids and sub and it sounds better. the points were where i had it for my last set up with a dayton ho12. I will definitely try using my mic to see if i can get it better when i have time. i have been adjusting some things little by little.
i will eventually rear fire the subs but i have not figured out how i am going to secure it yet(suggestions welcome). also in the process of trying to design some sort of amp rack and keep my spare in there.
Or fix the current problem first, and maybe you do not need to rear fire them?
More box volume, sundown rca’s 60$ but such a difference, or a pre amp line driver. Sound deadner always helps.
I wouldn't consider upgrading without playing with the current subs first. The Illusion C12's are no slouch. I'd face the current box towards to rear hatch, and consider sending them a little more power if possible.
One issue with the C12 is that it is a low profile sub and has reduced excursion(Xmax) due to that. It has 12mm where a normal sub might have 18-20 and high excursion subs could be near 30 mm of excursion. Since output volume is a combination of cone area (Sd) and excursion, this could explain the volume output issue. If you need shallow subs, the JL 12TW3 has 15mm of excursion so it might help a little but it wouldn’t be a big difference.
1 - 8 of 8 Posts
