I am looking for recommendations for subwoofer(s) to use two channels of 100w 2 ohm (75w 4 ohm) from my Jl Audio xd800 amp. I have audiofrog front stage (gb10, gb25, gb60) using 6 of the 8 channels so I cannot bridge the amp to get more power. Everything is controlled from a minidsp Dirac dsp.
I am currently using ZR800 8 inch infinite baffle drivers in the rear doors as subs. But the door rattles are just too much so I am going to build proper enclosure(s). I could just drop the two 8 inch 4 ohm zr800 drivers into the recommended .75 ft3 enclosures and call it a day. But since those are optimized for Infinite baffle, I am assuming there must be better drivers out there.
I have been toying with the idea of using a single 2 ohm dvc sub, probably 10 inch, as a way to get more power out of the amp. But I haven’t seen any 2 ohm dvc subs made for such low power. I have heard there could be issues with power mismatch between channels causing strain on the voice coil when using two amps on dvc drivers, but I am not sure how much to worry about that.
Using a pair of 2 ohm JL Audio 10w1v3 seems like a possibility as they suggest power as low as 75w. I think that would be better than the 2 ohm 10w3v3 which suggests minimum power of 150w.
This all raises the question for me of how to know which sub is going to produce the most output dBSPL per precious watt. I know the efficiency rating is not the way to tell this since that is measured at higher frequencies. Is there some sort of formula to wrangle the Thiele Small Parameters into a useful low freq efficiency number? That is just an aside.
So what sub drivers are best for a 100w 2 ohm amp? My main criteria is tight audiophile bass, but I think the marginal amp means I can’t waste power on overdamped subs.
