I have a 2006 bmw 550 with a 9" by 14" pass though in the rear seats. Is it better to mount a subwoofer directly behind this opening firing directly into the car cabin, or have a sub in the trunk firing toward the rear or side of the trunk
if you mount it facing thru the ski-hole then you should consider sealing the back seat off from the trunk, making a baffle if you will - to help avoid some reflected waves and cancellation.
it might work without, but should sound better if you do it that way.
I would take advantage of the pass-thru opening because you can get some killer bass, and save trunk space at the same time. You can go infinite baffle (lots of info posted on this method here, just do a search), sealed enclosure with the enclosure mounted to a baffle behind the seat and centered so the woofer is firing through opening, or ported, with the enclosure mounted to a baffle but with the port positioned so that it's firing through the opening, and the woofer firing into the back of the seat. The latter is a method I employed in my old Mazda 6 (see attached photo) and the results were spectacular. In each case I recommend you seal off the trunk from the cabin to keep the front and rear waves apart.
