Subwoofer Placement question
697 Views 6 Replies 5 Participants Last post by  pieces
Ok I know that firing into the cabin (towards the rear seats) is the norm, well at least around here. But what about placing the sub under the rear deck, facing the back windshield and using the 6x9''s (dead) as passive radiators ? or simply removing the 6x9's and let the air freely move through the 6x9 holes ?
Sealed box BTW
1 - 7 of 7 Posts
What sounds best will be different for every car. Try firing the sub in both directions and see what works for you. It all depends on where you will end up with the most interference, nodes, and what not.
Either way you will probably find removing the 6x9's beneficial. Making a good passive radiator setup is more complicated than this.
I agree with this.
Thanx I thought But never tried it, And i can really flip the box (custom)
Pretty much nailed it on the head here. Especially the part about passive radiators....
What model car is this in anyways?
does the sound actually reflect off glass, or is it better to reflect off panels?
Glass is the most reflective surface in the car. But really, anything hard and flat = good reflections.
1 - 7 of 7 Posts
