I'm after the best solution for doing a tub in my suv, and this time I want to do it right. I've used cheesy mat and crappy bondo brand resin in the past, and the level of failure I've had w/ fiberglass is just...phenomenal.
So, here's the target:
It has a full deadening layer now, this pic was when I first gutted the back end.
This is what I was working with last time:
This old design uses too little airspace for the incoming DIYMA subs, and the new box will need to be a LOT thicker as well. This one flexed at the bottom because my glassing skills and material choices were lacking. I'll do it right this time with your help, I'm sure of it.
So, what type of fiberglassing materials would you recommend? Where would you get them most economically? I have a lot of ideas but I want some opinions on this one before I pull the trigger.
Thanks!
Thanks!
