$200 shipped in Continental 48 for the SAX-125.2
Paypal me at [email protected] to order OR contact your favorite Sundown Audio dealer.
AK and HI contact for shipping rates.
FOR USA ONLY.
SPECIFICATIONS:
o 2/1 Channel Bridgeable Class-AB Amplifier
o MOSFET PWM Power Supply
o Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
o 12dB Octave Electronic Crossover Slope
o Variable Subsonic Filter
o High Pass Filter Variable with x 10 Range Selectable Switch
o Low Pass Filter Variable with x 10 Range Selectable Switch
o HPF/FULL/LPF Selectable Switch
o Variable Bass Boost Control
o Variable Bass-Boost Frequency Control
o Variable Input Level Control
o Input Sensitivity : 200mV ~ 6V
o Subsonic Filter : 10Hz ~ 500Hz
o Signal Input and Line Out RCA Connectors
o Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
o Tested Voltage & THD: 14.4V & Less than 0.05% THD
o Operating Voltage : DC10V~16V Power Input
o Wired Remote Controller
o MSRP $349 USD
Rated power output
----RMS power, 4 ohm stereo
125W x 2CH
----RMS power, 2 ohm stereo
200W x 2CH
----RMS power, 4 ohm bridged
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 50Hz ~ 5KHz
High Pass Crossover 30Hz ~ 3KHz
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
[email protected] Watts <0.1%
Channel Separation 75dB
Fuse Rating 20A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 340(L)mm
FOR USA ONLY.
SPECIFICATIONS:
o MSRP $349 USD
Rated power output
125W x 2CH
200W x 2CH
400W x 1CH
Bass Boost 0~18dB
Fuse Rating 20A x 3
