1 - 5 of 5 Posts
looking for help to retain the rearview mirror backup screen to be tied into a kenwood ddx9906 HU. 2013 Tacoma truck.. what would i need and which wires to tie into..
303511
looking for help to retain the rearview mirror backup screen to be tied into a kenwood ddx9906 HU. 2013 Tacoma truck.. what would i need and which wires to tie into.. View attachment 303511
Which harness plugs directly into the mirror?
Look at that one. Should be a ground. A constant 12 volts. A switched 12 volt.
Then depending on if its a switchable view or not you could have 2 video wires or 4. After you find the ground and what not there should only be 2 or 4 other wires left. Those will be your video wires.
And depending on the polarity the image may not be there at all. Flip the wires in that case. Or the image might be reversed. You can try and swap the polarity again. But it may just end up being reversed. Depending on what you are doing.
1 - 5 of 5 Posts
