201 - 208 of 208 Posts
This is with FIR off, right.
100hz is the sub/midbass x-over point. Door enclosure port is tuned to 80Hz.
Engine running adds some info at 40-50Hz, which i could also observe on REW measurements. Sweeps overpower the engine hum by 20-25dB. Will recheck again.
Ported enclosures always have smeared impulse response. You essentially have 2 point sources with them. The front of the cone and the port. The port will be delayed.
Here's my first tune with APL1 & TDA and I am very amazed with the results. Will try to fine tune my crossovers as there are some dips to take care of. any advice will be much appreciated. :)
Btw , I am using the MS8 curve for APL1.
My set up is 3 way active :
1. MB - 40hz/24db..600hz/24db
2. Mids - 800hz/24db--3khz/24db
3. Tweeters - 3khz/24db
SPFR with and without APL
