OK. I have a few more changes to make to my system before the winter freeze. Here is #1.
I absolutely love my Scanspeak D2904/60000 tweeters. But, they are 15 years old. I want to see how a current generation pair of D2004/602000's compare.
For thought and inspiration:
Also installing tweeter protection capacitors. 80uF non-polar audio grade electrolytic:
I was glad to see the tweeters dropped right into the factory spring clip retention system. I was sure I was going to make modifications. As it turns out no
The protective grill on the tweeter extends about 10mm above the tweeters dome. There was a 5mm interference fit between the dome and the factory grill. So, pop the tweeter grill off with a set of needle nose pliers. The grills come off with very little force applied. The tweeter only needs 1mm clearance. A 4mm gap still exists.
Note the factory grill was warped due to an interference fit with the old D2904's. I am hoping it will flatten out again now that there is no longer a tweeter grill pressing against it.
Ge0
Ge0
