Actually, I lost my hair many years ago, but if I had hair, I'd be losing it!
I promise; I did my due diligence.
I've been all over this site, the Helix DSP tuning "magazines", Andy's tuning guide, consulted clergy and medicine men, etc, and the more I dig, the more confused I'm getting. Seems like there's a million ways to do this, and it seems like there really ought to be something approaching a few "best" or at least better ways.
I had no problem setting the input gain on the DSP (.wav 0dB 1kHz mono sine tone, 9'10ths max HU volume with all bells & whistles flattened, neutralized, or off, turn up gain until clip light comes on, back off until it turns off), and if i simply had a HU and amp: same HU setup except volume at max, true RMS voltmeter connected across speaker output, turn up gain until you get the square root of the product of rated power and speaker impedance (strangely, there was an MTX video where the guy showed an equation of the square root of PR, so I'm kind of wondering if either he screwed up, or maybe I'm spota use the product of rated power and the DCR of the driver?) in DC volts. Other than that bit of confusing data; easy.
Where I'm getting confused is in the proper point (and procedure) in which to set up amplifier gains with a DSP. Firstly, I have 5 gains; 1 for each bridged channel for the mids, 1 for the sub (this is the 900/5 amp), then 1 each for the bridged tweeter channels (the 400/4 amp. Overkill, I know, but this is temporary, until I get the OEM speakers back in the rear door. They're not bad sounding at all, and they're just for rear fill, and simplify the Hell out of all this, being full-range. In the interim, I just turn the gains way down on this amp, and never have to worry about sending a clipped signal to these expensive tweeters).
The confusing part: if I set up the amp gains from the DSP first, then do all the DSP-ing, it seems to me that I'd have to set the gains again after the DSP-ing, to account for all the dipping and possibly a bit of boosting. Resetting the gains then changes the response, especially because I have all of these gains going to the sub, mids, and tweeters, so I'd have to go back and RTA-EQ it again, then re-set the gains, then RTA-EQ it again, etc, etc....
It's really no different, in my mind, if I do the DSP-ing first, except that maybe this is a less-safe way of doing things.
Is there anyone who can shed some light on this for me?
I'd be extremely grateful!
