Hey guys. Here is what I need help with. Since rear is just mainly for fill would it be better to have just a mid bass driver in the back doors or should I just stick with a coaxial speaker. Any help would be great. Thank you and god bless
That’s kind of what I was thinking but didn’t know for sure. I just wondered if it would sound weird with no high’s coming from back thereJust midbass. High frequencies behind you need to be handled with care. If you have a DSP to do a proper rear fill setup, and the knowledge and interest in tuning, then the answer may be different. However, for most circumstances you won't want high frequencies behind you.
What other problems? I’m not an spl guy. At 48 I just want the best sounding system I can get. Just pure soundIdeally rear fill is mounted up high and with a band pass of 300-3500hz. Some prefer rear fill to be stereo but again mounted higher is better. Now as far as midbass in rear doors some have used it as a midbass and ran 80-300hz and t/a to the driver in single seat tune. This of course opens up other problems. Just some things to think about. Dave
Oh, I don’t want that. I want the stage to front and center on the dash. Looks like I will be staying with coaxial for the rearsPhase issues with the front midbass and can pull the stage to the rear primarily.
Already have the subs. Gonna run a triple 8 ported setup from skarCould run them as subs depending on what you have to fulfill that role...
High frequencies are going to pull the stage back much more than anything. If you want a good soundstage that is up front and center, do not use a coax, use only midbass. If you have a DSP to get the rear midbass aligned with the front, even better, but if you don't have DSP, then a coax is going to be much more problematic than just using midbass speakers.Oh, I don’t want that. I want the stage to front and center on the dash. Looks like I will be staying with coaxial for the rears
Ok. Thank youHigh frequencies are going to pull the stage back much more than anything. If you want a good soundstage that is up front and center, do not use a coax, use only midbass. If you have a DSP to get the rear midbass aligned with the front, even better, but if you don't have DSP, then a coax is going to be much more problematic than just using midbass speakers.
I can't say that I agree completely with gijoe in regards to how to implement the rear speaker locations in this instance.Ok. Thank you
Well, you lost me. Ha! But that’s ok. From what I get it sounds like it would be ok to run a 6x9 coaxial for the rearI can't say that I agree completely with gijoe in regards to how to implement the rear speaker locations in this instance.
In general, I think we can all agree to put most of your money towards the front stage component speakers, as that will ultimately determine how good your front soundstage will be (along of course with solid speaker mounting baffles/rings, thorough sound deadening treatment that seals any openings or holes in the front door's sheetmetal panels where the speakers are mounted, and of course, proper tuning with a capable DSP).
But there's absolutely nothing wrong with wanting a decent pair of coaxial speakers in the rear for when you have rear seat passengers. You can simply Fade them to a level where they aren't detrimental to the front soundstage when you don't have any rear passengers.
OR, you can use them to add Ambience and Space to the listening environment and enhance the front soundstage by using standard stereo "rear fill" where you raise the rear volume until it just starts to pull the soundstage towards the back, then add between ~12ms to ~23ms of to delay to them until it shifts the soundstage forward again.
For this to work well, Andy says that you really only need a HPF above ~100Hz (or a HPF at a slightly higher frequency that is appropriate if it's a smaller speaker) and not a bandpass. According to Andy, a LPF to reduce the high frequencies in the rear fill is not necessary or is optional. But I sometimes apply a low order ~4-6kHz LPF or gentle shelf filter depending on the proximity/location/aiming of the rear fill speakers to the listening position. IME, at a real or live venue that has "late" or distant reflections, the higher frequencies naturally roll off a bit and lose energy or amplitude over distance. And I usually land on a 160Hz HPF for the stereo rear fill.
Andy at Audiofrog has suggested and prefers this "standard stereo rear fill" technique rather than using what we refer to as "Differential Rear Fill" which can produce some very odd effects on some music (depending on what techniques were used during the mixing process).
Personally, I wouldn't try to implement the rear speaker locations to try to enhance the midbass response of the front stage. Instead, I would use the subwoofer to do this as per ErinH's YouTube video titled, "Using your Subwoofer to Improve your Midbass" on his Erin's Audio Corner YouTube channel.
I get the impression that OP does NOT have DSP, which is what is motivating the responses I've given.I can't say that I agree completely with gijoe in regards to how to implement the rear speaker locations in this instance.
OR, you can use them to add Ambience and Space to the listening environment and enhance the front soundstage by using standard stereo "rear fill" where you raise the rear volume until it just starts to pull the soundstage towards the back, then add between ~12ms to ~23ms of delay to them until it shifts the soundstage forward again.
Sorry guys. Should have said this first. Here is my car and systemI get the impression that OP does NOT have DSP, which is what is motivating the responses I've given.
If OP has DSP, and the time and interest in tuning rear fill into the equation, then my advice would change.
Without DSP there's no way I would add high frequencies behind me if a good soundstage was the goal.
