1 - 20 of 182 Posts
I have a 2016 silverado regular cab. No pictures uet but i figure i should start something. Im still waiting on a few parts
It will consist of 2 way active front stage using stock locations with oem headunit
Eric stevens components ran off of a digitsl designs d4.90 and 2 sundown sa6.5sw subs ported tuned to 35hz ran off of a matching digital designs 500.1. Along with a mosconi 4to6
Front stage has been changed due to a bet people here sre telling me passive sucks and it wont sound good. Challanhe accepted. Im still using thr same amps but thr front stage will consist of DRT-26 Silk Tweeters, ES-02 Midrange, HD-M6 Midbass Drivers, MX-1000SX Crossovers. They have been ordered from @ANS i am not working on the interior deadaning and that stuff.
Sub'd
I love a lowered RCSB!
Mybuddy will be doing the install. Some people here may remember Mr.Marv. im just prepping the truck for him doing the desdening and what not
But its been over 4 years sincei have had any sort of audio. And igot burnt out on the SPL stuff.
Imhoping this turns out good. As i have never ran passive before
I've heard plenty of passive setups that sound good. With that being said, I have no doubt they would sound better going active.
You already have a Mosconi dsp, why not use it?
I am using it issue is its only a 4to6. To run 3 way active id have to upgrade. Also i have minimal room and i mean minimal. I found a matching set of amps that fit and im not buying new amps.
So thered those few reasons
If you have had active systems in the past, I have no idea how you are going to be happy with passive...
I would take a 2way active over a 3way passive any day. Though, I am not sure if that makes sense with the equipment you already have...
IMHO
IMHO
All ive ever had was active. I was going to run 2 way active. BUt as mentioned earlier. This is a bet that i have to come through on
If there was no bet. Id be 2 way active done and good
Oh, I see... Looking forward to seeing what you come with, nonetheless!
Those ES02 would work fine as a 2 way active. Crossed around 1200-1500 they meet any decent 6.5” mid bass. They play well into the 17k range and unless you are an 18yr old kid you can’t hear past that anyways :)
As noted I will take an active 2 way over a 3 way anyday. The tuning options are much better.
I am in on this one, can’t wait to see the install!
Discussion Starter #13
Those ES02 would work fine as a 2 way active. Crossed around 1200-1500 they meet any decent 6.5” mid bass. They play well into the 17k range and unless you are an 18yr old kid you can’t hear past that anyways <img src="http://www.diymobileaudio.com/forum/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Ya i hear you just something i want to try. And it will only stay in thr truck a few months as i have a set of eric stevens components (active version) sitting here in the garage that are going to go in after
Again. Its just to prove a point. I like challanges
Discussion Starter #16
Looks good.
I believe ccf is essential whether or not you will be using mlv.
Following.
My understanding since way back was ccf is just a decoupler for MLV. But it doesnt hurt anything having it i guess.
I have a ton of melemine foam as well im sure i can stick somewhere too
Looks good.
Following.
I use it to decouple the door skin from the plastic panel. Before I had tons of rattles and resonating
1 - 20 of 182 Posts
