21 - 40 of 51 Posts
· Registered
Just some further consideration for the Hilux:
Alternator kinda sucks
You need to deaden the entire cabin, especially the fire wall. This means dash out.
Will need to drill the firewall to fit 0awg and grommet/waterproof fitting
Doors need alot of work to properly deadern and seal, the ute has basically none from factory. Will still have buzz from the window mech nonmater what
Will need to make your own solid mounts for doors, the pre-made ones are crap.
Air bags make pillar mounted mids tweets difficult.
· Registered
Discussion Starter · #23 ·
That looks a nice build you are getting there. Definitely looking for more pics :)
Also can you please provide the setup detail?What equipments and what are you using?
· Registered
Automotive tire Audio equipment Public address system Entertainment Gas
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Vehicle Motor vehicle Hood Automotive design Automotive tire
Automotive tire Automotive lighting Hood Motor vehicle Automotive design
So these are pics from my install, I ended up adding more dynamat than what you can see here. The panel just behind the rear bench headrest needs to be removed and treated with some kind of decoupler, I used 3M VHB double sided tape. After placing that panel and rear seat back on, I wedged rubber mat between the seat back and the panel to ensure there was no rattling.
For window resonance, I don't seem to have any at all, maybe because my window tint is super thick.
I found some rubber carpets at a local shop and made floor mats for additional sound deadening, seems to do the trick.
Now that my install is complete, I can honestly say I'm not wanting more. It sounds just how I imagined it would. The single 13TW5 can boogie, the 2 way active audiofrog gb setup is incredible and my amps run pretty cool. I may swap out the rear fill speakers to something more budget since I'm not using the Morels as they were intended (bandpass 500-2800).
Anyways, good luck with your install.
· Registered
Forgot to mention. I have an auto, not sure if the manual transmission is any different, but there was a nice unused grommet behind the engine on the firewall to run my 1/0 AWG wire, then I ran it alongside the passenger side trims. Everything popped back in place like factory.
· Registered
Discussion Starter · #26 ·
I had a question about the air vents in the rear panel, yours seems to be covered, are these causing any issues?
Textile Musical instrument Wood Art Font
Automotive tire Tire Motor vehicle Bumper Grey
· Registered
I know the pics aren't the greatest, but the six channel amp on the left is a DSP. Yes the pods and speaker rings are from Germany, I contacted him directly on WhatsApp from his website, but he does have the ebay site.
Yeah my car is one gen earlier, I stripped the entire car apart, didn't see any vents.
· Registered
Discussion Starter · #34 ·
I tried everything a subwoofer can't seem to fit in the rear 😔 I have the 2021 model.
Even audison apbx 10 won't fit. The only option seem to be apbx 8.
· Registered
Discussion Starter · #37 ·
I have also seen this;
It all says fits 2015 and above The above one even says for the 12-inch JL. I wonder how. My installer said he tried all options.
I am not sure if 2015 and above is all same space behind the seat or something changed in bwn.
· Registered
This is where I got my sub and box. These guys do really good work and I know they have a 13tw5 for your model year Hilux.
· Registered
Discussion Starter · #39 ·
I just sent them an email. But the price they have posted on the website seems crazy. I just need the box.
21 - 40 of 51 Posts
