41 - 51 of 51 Posts
· Registered
Discussion Starter · #41 ·
I have sent them an email. Will need to see the cost with shipping. But $1000 for a sub box, isn't that a bit ridiculous?
· Registered
Discussion Starter · #43 ·
I got the quote Aud $1450 for the whole package excluding shipping that's still a lot for me.
I am now looking at underseat options. Maybe use a jacker and lift the seat a bit and add some shallow 8 inch. Came across the skar vd 8.
· Registered
Discussion Starter · #46 ·
· Registered
Do you have more pictures of your rear firewall? i see you have a box there labelled "CAN" or something?
i presume the 2021 version is similar to the other 2015+ models in terms of the amount of space there, so I do think there's a solution for you to go behind the seats.
This is my layout at the moment - excuse the mess, was waiting on some more cableties!
Automotive design Motor vehicle Luggage and bags Electronic instrument Audio equipment
· Registered
Discussion Starter · #48 ·
Yes you are correct, there is no way to put the subs behind the seat. So I went ahead and put in the Nuclear amp which has filled up the whole space almost :p. Will share some pics soon.
For now I have the attached.
· Registered
You want photos of my firewall where I've run my power cable?
· Registered
Discussion Starter · #51 · (Edited)
I finally got two subs under seat. It's the Skar Audio VD-8 D2 dual 2-ohm. For now I am each amp directly to amp in series, and my amp is 660w at 4-ohm. I will be changing this to 2-ohm and the amp power at 2-ohm is 1200W. Each sub is 400w
Attached some pics and box details; pardon the drawing :p
The passenger side seat needed to be lifted a bit. The driver seat has the height option, with the height kept at highest its fine. The passenger seat doesn't have any height adjustment, the sub goes in fine but the lift was done to make the seat movement smooth.
Rectangle Font Handwriting Parallel Automotive exterior
Bicycle Tire Wheel Bicycle wheel Bicycle tire
Automotive tire Grey Automotive exterior Bumper Gas
Public address system Output device Camera accessory Sound box Wood
Automotive tire Automotive exterior Bumper Asphalt Automotive wheel system
Car Vehicle Motor vehicle Automotive design Personal luxury car
Automotive tire Road surface Asphalt Wood Floor
41 - 51 of 51 Posts
