This is not a bash, I love the MS8, but am out of ideas and would like educated opinions/guidance on anything I possibly may be overlooking.
My set up is as follows
F150 with factory nav/sony sytem
High/Mid's are summed to the MS8, low was summed to input channel 8.
Signal is grabbed after the factory amp since it's impossible to get it before the amp b/c of the way audio is sent to it.
All 8 output channels are used. The MS8 powers side speakers which are polk 4 ohm, and everything else is ran off an external amplifier.
The first MS8 I had only worked for about a day. Turned the vehicle off, and it wouldn't come on anymore. Since I had bought it from an individual, I bit the bullet and bought another at full retail for the warranty. I plugged it in and it worked for about a month. I was having a turn on pop issue, after some help learned that it was because the factory amp was turning on before the MS8, which was not preventable. There was no way to have the MS8 turn on the factory amp so I wired in a delay for the MS8 to turn on later. This prevented the turn on pop.
Had the 2nd unit for a month with no real issues except lack of full midbass which there are many threads on. I EQ'd it to my liking and 2 weeks later it stopped working. Checked power/ground etc, had voltage across the terminals, unplugged everything but power/ground/remote in/out, still wouldnt power up. Hit the reset light, the external amp would cycle on, the LED would light up, and then it would turn off in about 5 seconds.
RA'd it and received the replacement a week and a half after I mailed it which was last week. Direct plug in and everything was good. EQ'd it straight off the bat. 3 days later it to turn on. I rechecked everything, unplugged all connections except power/ground/remote in/out hit reset, LED came on again, turned off in about 5 seconds. So once again I have RA'd it, mailed it express on Saturday so it would be there on Tuesday. Im getting tired of no sound.
I've spoken with some tech's at JBL but they are unable to see what the technicians diagnose, they receive the unit, and send out another. I don't know what the problem is. The install is pretty straight forward. I've checked and rechecked all connections. Hooked the MS8 to a external power supply and it still won't turn on but for 5 seconds after hitting reset. I am worried it has something to do with the internal amp b/c I read some people were having issues.
Any ideas or just bad luck?
