1 - 18 of 18 Posts
Banned
Just like the title says, I add the caps, turn on pop, remove them, it goes away. Ive tried multiple amps, it does this with all 3 ive tried. Im assuming its the capacitors... I'm currently using these elna capacitors 33uf... see picture. Currently using dynaudio tweeters, I have a set of new Audiofrog GB15s im getting ready to install. Before I put them in I want to get some caps that dont cause a pop. Anyone using inline caps on GB15s or any other tweeters @ 4 ohms plz let me know what the brand & value of caps youre using. Im shooting for 1500hz or so, i think the 33uf at 4 ohm came out to like 1200hz or something around there.
Alternative option is to set the crossover/high pass on my amplifier (Rockford t400x4ad) to like 1000hz... its 12/db per octave so that might be a solid option since I will be crossing over around 2k to 2.5k on my dsp well above that... I just want to avoid damage to the new audiofrog tweeters with some sort of protection...All it takes is one screw up and they're toast.
Thanks
273658
The caps should not cause a pop.
Are you sure it is from the tweeters?
Following this to see what the fix is. I just happened to read yesterday Andy's tech tip about putting a cap on tweeters.
Maybe try a different cap? Maybe get a 100v and see if it helps.
This tends to happen with certain amps. Also, use a non polarized cap. All else fails, use a fuse instead
Banned
It might be a combination of the caps and the tweeters but when I change the amp, the pop remains, and I’ve tried 3 amps. Arc x2 1200.6, Polk pa4000.4 (same as nvx jad/ppi), and now I’m using rockford t400x4ad. I remove the cap and no pop. So My best guess is it’s the cap. I guess I will try buying a few different brands of non polarized caps and see if any of them fix it.
I also have them only a few inches from the amp, not sure if that would change anything I know some people say to put them right next to the tweeters, and I’m doing the opposite with them only 6 inches from the amp.
I've used polarized caps, I seem to remember you need to have two in series with one wired backwards for it to work okay (or was it in parallel?). I only did that cause I was being cheap and didn't wanna buy more parts.
It's better just to use the right cap for the job.
All three amps ?
If you remove the cap and no pop, I guess that is solid detective result.
I installed non polarized capacitors on my GB15 and no issues but when I installed them on my GB10 in my truck I all of a sudden got the pop. The GB15 is run by a Pioneer PRS amplifier and the GB10 by a cheap D8604. It’s not bad enough for me to care though so I left it as is.
I'm curious about the fuse idea, I’ve seen this on a few home speakers.
Banned
Discussion Starter · #10 ·
Do you remember what voltage you were using on the GB15s when they did not pop?
I'm going to get a few to try out and also try putting them right next to the tweeters instead of right by the amp.
I have never heard of the fuse thing, I'm going to check into that...
Banned
Discussion Starter · #14 ·
Do you still have the crossovers? They should get you around 2500hz 12db
Yes I do! I will have to look into modifying them they are higher than the crossover point im trying to do. I halfway blew one of the dyn tweeters (making some weird buzz noise) so I bought some GB 15's but have yet to hook them up yet. The woofers though, I dont think I could blow those if i tried. I tried some other woofers and ended up going back to the dynaudios. They are great woofers!
Crossing lower than 2500 probably made tweeter unhappy. I am not positive 2500 is correct may be worth looking into. Glad the woofers are working out
Banned
Discussion Starter · #16 ·
Yes, thats a possibility, I'm going to shoot for 2500 on the DSP and like 1500 on the passive protection. Thats why I'm trying to get this worked out so I dont burn up another tweeter. Yeah the MW162 woofers really came alive once i got my dayton DSP to do some adjusting. They are solid performers
Common issue w some class D amps. We have the issue in my wife's car using Arc 1200.6 amps.
Happened w the X2 amps as well.
I had the same issue...changed to Zapco AP amp. No pop.
And as you've noticed, if you remove the cap it goes away. As Nick said above, add a fuse.
Could also look into something like these
Arc and a few companies used to include them w Tweeters
Banned
Discussion Starter · #18 ·
Oh yes, I have had so many interference/noise issues with class d amps. They have mostly all been fixable with little tweaks to my ground etc and worth the trade off in efficiency but the class A/B amps...Its just like hook up and Go, no problems. Honestly my favorite class D is my Rockford t400x4ad I just got a great deal on it refurbished. The noise floor is absolutely insane, its S/N Ratio is one of the highest ive seen when measured at 1 watt 4 ohm. I can have the gain turned up to 75% before i start hearing humm or hiss. And it seriously sounds like a class A/B. Warm, smooth. I really gotta give it to rockford on the compact power amps. I personally prefer it over the Arc X2. It does only have 4 channels but they are so small you can easily hook up two of them.
Im going to check out those protectors, never seen them before. Thanks!
1 - 18 of 18 Posts
