Hi all I just did an overhaul on my audio in a 2016 chevy cruze limited and that install is complete but now the techy stuff needs tinkering with.
I'm gonna try to list everything in this system so that there is no confusion and hopefully I can narrow down my issues.
Main Concerns
1. My tweeters overpower my mids and blast my ears before I can get close to my distortion number(32) on my factory headunit. Hit about number 20 and it's about the loudest I can comfortably listen but the mids are no where near how good they can get.
2. My door chimes/turn signals are now annoyingly loud and i'm not sure if there's equipment I need to install or how to bypass this.
3. I have a whining noise now that I would like to address.
I'll start by detailing the install. I disconnected my rear door speakers and am only running 2 front door woofers and 2 tweeters. They are each ran to their own channel on a compact 4 channel amp. I have an lc2i running from my factory radio and that feeds from the main output to a minidsp which then leads to the 4 channel amp that powers my front stage and then the bass output runs to a mono channel amp that powers a single 10" subwoofer. I have 4 gauge wiring that runs to a fuse block and it's grounded to the chassis of the vehicle and everything runs off of the block.
Equipment:
2016 Chevy Cruze Limited
Front stage setup
Door Speakers: Silver Flute W17RC38-04 ohm 6-1/2" Wool Cone
Pillar Tweeters: Vifa BC25SC06-04 1" Textile Dome Tweeter
LOC: Amazon.com: AudioControl LC2i 2 Channel Line Out Converter with AccuBASS and Subwoofer Control : Everything Else
DSP: miniDSP 2x4
DSP Isolator: miniDC Isolator
4CH amp: Amazon.com: Alpine KTP-445U Universal Power Pack Amplifier : Electronics
Fuseblock: Amazon.com: WUPP 12 Volt Fuse Block, Waterproof Boat Fuse Panel with LED Warning Indicator Damp-Proof Cover - 6 Circuits with Negative Bus Fuse Box for Car Marine RV Truck DC 12-24V, Fuses Included : Automotive
Bass:
Subwoofer: https://www.crutchfield.com/p_575P1S4102/Rockford-Fosgate-Punch-P1S4-10.html
Mono Amp: https://www.amazon.com/Rockford-Fos...ds=rockford+fosgate+amp&qid=1632792888&sr=8-7
I tried to include everything but I'm sure I've missed something. I'll add some more install notes now.
Each door was treated with deadener and I installed custom mdf speaker ring adapters with speaker foam tape as well as silicone baffles
to help seal the door speaker to the panel and direct the rear waves into an eggcrate foam pad. This whole setup was recommended on another
forum regarding chevy cruze audio installs. This person posted their setup piece by piece and had at least 20 other cruze owners using the components
and having solid results with them. They also posted the "tuning files" that matched the speakers I'm using and the same car interior which should get me
in the ballpark of a nice sounding system. Everything was great until I started setting the gains and here's why.
I started by setting my gains on the mids in my car. I had already come to the conclusion that my headunit sends out an undistorted signal at the number 32 so that's where I'll have my volume at. I unplugged all of the other speakers and ran a -3 db 1,000hz test tone. I heard volt matching is what you want to do to get your peak performance from your equipment and be sure you're getting the most powerful clean signal from your head unit to your amps. So my 4ch amp states it accepts 0.2V-4V and so on my LC2i I turned my main output up until it was hitting close to 4V. From there I started turning my gains up on my mids until I heard distortion. Then I played some music just to check and listen for distortion and wow my door speakers were sounding amazing! I was so happy with how powerful they hit and how much rumble I was getting from my doors. It really brought the sound to life. After that I plugged my tweeters in to match them and immediately boom! They were so powerfully loud I couldn't even break number 20 on my radio without my ears screaming. So at this point Idk what to do. I start fresh and cut the Volts in half from the LC2i. Now I'm sending 2Volts to my amp and this makes me have to turn the gain up much higher on my mids channel now and it doesn't sound nearly as nice. Even at this 2 Volst setting my tweeters are still overbearingly loud with 0 gain on their channel.
I wanna mention that in between the LC2i and the 4ch amp there is a miniDSP which is supposed to set my crossover points and set latency on each individual driver so that I have a more clean sound stage. Other than loading in this persons file that had "hours" of tuning and plugging it into my system I've done zero tweaking with how this person has the crossovers set. I'm curious if I bought a rta mic and tried to tweak the system and possibly roll the high frequencies down if it would solve the insane shrill noise they seem to have on my ears when trying to enjoy a nice booming sound.
But that then leads me to my next issue. If I do Volt match again and bring the Volts back to 4 where the mids sounded amazing previously then I will have a lot more noise in my system. There is a whining noise that increases as I rev the engine. On top of that a higher output from my LC2i means that my door chimes and turn signals will be even more insanely loud then they already are at 2volts. I've got a solid ground but I haven't done the big 3 upgrade which some sources claim may solve the whining issue. I'm tempted to take my vehicle to an audio shop and see if they could possibly tweak everything right but for whatever reason I have more faith in myself to learn it and adjust it properly then to trust the shops around here to touch my stuff lol.
Anyways I think I've covered the majority of my install and issues that need resolved so I hope someone could possibly shed some light on what could be my issue. I didn't mention any bass related stuff bc it's perfect and has no issues. I volt matched to 4 on that as well and set my gains with my oscilloscope and it packs way more power then i'll ever need so I mostly keep the bass knob turned to the lowest setting for regular listening.
Thanks in advance everyone!
Main Concerns
Equipment:
Front stage setup
DSP: miniDSP 2x4
Bass:
