1 - 20 of 60 Posts
You've probably seen this beast in the SecondSkin install videos and also on our YouTube channel. Vehicle is owned by FloridaSPL's Buzz Thompson. The truck is a 2008 single cab Toyota Tundra with a TRD supercharger (over 500hp) has less than 9k miles on in.
2 layers of Damplifier Pro, 6 layers of Spectrum, and a layer of Luxury Liner Pro are going in the cab. The doors... well the doors are done to the extreme as you've seen in the videos.... The doors are almost 5' long and have take about a bulk pack of Damplifier Pro in each.
The Truck
Buzz Starting on the first layer of Damplifier Pro on his 5' long doors.
Once he starts he can't stop..
You guessed it.. time for Spectrum..
Spectrum after spraying..
About a month later after adding layers of Spectrum, it's cured
I find it interesting that you guys used that expanding foam to fill the cracks as I was just reading a build log on a guy that used an expanding foam for the purpose of stiffening his chassis. Apparently it's measured in "pounds" and can very significantly strengthen the chassis of a car... I wonder how much something like that would help your cause?
I would think that the foam you used seals crevices, but wouldn't add very much strength, which you'd probably only need if you're going for SPL....
Some pretty nice work you're doing there too though! That takes a lot of patience, that's for sure!!
Holy **** this is a tomb on wheels now. Great job man.
Wonder if you'll be able to hear outside sirens and cars passing by :) Very interesting!
Since deadener doesn't block sound (well), I would suspect his truck will still be plenty loud inside. The windows are also the weak link in sound blockage anyway.
I hope you are sponsored..... I probably bought 3-4 cars for less than that much deadening material. Looking great!
1 - 20 of 60 Posts
