1 - 20 of 146 Posts
· Registered
This forum used to be more about finding very good low distortion drivers that were unique that anyone could afford to use with maybe a little extra preparation for use in a vehicle. Currently trending on this forum are high end car audio specific drivers from companies like AudioFrog, Dynaudio, Focal, Hybrid Audio, and Hertz. These are great, and definitely are proven drivers, but they are also not the only options out there. Many of these car audio specific high end drivers from the above car audio brands also cost a lot of money and that is understandable given the limited market they are in.
These car audio specific drivers must also be designed for use in extreme environments and still offer a long warranty or not fail in a year in those environments. I think people who tend to purchase these car audio drivers also tend to abuse them, and they may not understand how to implement them properly like using a high pass filter to remove sub bass frequencies from them so they don’t exceed their excursion limits.
In this thread I put together a list of drivers that I identified as useful for car audio from places or sources some people may have forgotten about. Most have TS parameters that work for quasi-infinite baffle use in a car door and most don’t have open or exposed voice coils that will degrade in the potentially wet environment of a car door. They also have cones that will stand up better than a typical paper cone driver made for home audio use would.
I’ll start out with 6.5” mid woofers and then move onto 8” mid woofers. The 6.5” mid woofer is the most common and versatile size that can be used for both two-way and three-way front stage systems. The drivers with inductance reducing shorting rings will and smoother upper end frequency responses are best for two-way front stages, but these also tend to cost a bit more because they are harder to make. For a three-way front stage that requires less from the mid bass driver with a narrower passband, typically 80 Hz to 400 Hz, one can get away with a less costly driver.
A driver that is designed to be used for a specific task such as a true woofer will do better for that specific task and should cost less too. You may give up an extended smooth upper range frequency response but gain efficiency in the lower mid-bass region which is good for three way systems.
Finally, an 8” driver is really best for a three-way system in a car audio environment, mainly because of the beaming characteristics of the larger diaphragm, and the typical off axis lower door placement that most of these will end up in. They also tend to be deeper, so implementing them in many car doors may only be for a select few. With a decent low distortion subwoofer however a 6.5" mid-bass driver is all you really need. If you want very loud though some 8" drivers may be a better option.
Since AudioFrog makes fantastic midbass drivers I will use those as the benchmark to compare to when modeling.
First up is the Scan Speak Discovery 16W/4434G00 from Madisound. This driver is made for car audio by Scan Speak, and its relatively shallow so it will fit in many places. It has an fs of 55 Hz and a total Q or Qts of .48. Madisound offers this driver in one of their auto sound kits with the the R1904-613001 tweeter and passive crossovers which is also made for auto sound. It can be had for a modest $118 each.
Scanspeak Discovery (red) vs AF GS60 (blue) vs AF GB60 (purple)
Slope Rectangle Plot Line Parallel
With a proper HP filter on it I think the 70 watt rating is about right but as you can see you cant put 70 watts on it without it.
Rectangle Slope Plot Font Parallel
· Registered
Next up is the Scan Speak Silver Series 16W-4531G06 6.5" driver from Madisound. This driver is made for car audio by Scan Speak and has a unique split paper cone and neodymium magnet system. It has an fs of 51 Hz and a total Q of .59. The price on this driver is a high $322 but it also has some of ScanSpeak best technology. Scan-speak 16W-4531G06 Autosound Woofer
Scanspeak Silver Series (orange) vs AF GS60 (blue) vs AF GB60 (purple)
Colorfulness Rectangle Slope Line Font
Scanspeak Silver Series (orange) vs AF GS60 (blue) vs AF GB60 (purple) excursion. You will need to implement a proper HP filter to avoid exceeding excursion with this driver and it is rated for 70 watts RMS but the efficiency is good in the lower octaves so it will get loud on less power. This driver should have a HP at around 80 Hz and be used with a subwoofer.
Rectangle Slope Plot Line Font
· Registered
Next up is the Scan Speak Gold Series 16W-4538G05 6.5" driver from Madisound. This driver is made for car audio by Scan Speak and also has the same unique split paper cone and neodymium magnet system like the silver series. It has an fs of 36 Hz and a total Q of .35. The price on this driver is very high at $403. It might be best to use this driver in an enclosure rather than inside a car door where the TS parameters don't lend themselves as well to this condition. 16W/4538G05 Gold Series 6.5" Mid-woofer
Scanspeak Gold Series (yellow) vs AF GS60 (blue) vs AF GB60 (purple)
Scanspeak Gold Series (yellow) vs AF GS60 (blue) vs AF GB60 (purple). You will need to implement a proper HP filter to avoid exceeding excursion with this driver and it is rated for 70 watts RMS.
· Registered
Next up is the Scan Speak Revelator 18W/ 4531-G001 7" driver from Madisound. This driver is made sort of for car audio by Scan Speak and also has the same unique split paper cone but ferrite magnet system. It has an fs of 33 Hz and a total Q of .35. The price on this driver is average at $209.50. It might be best to use this driver in an enclosure rather than inside a car door where the TS parameters don't lend themselves as well to this condition but would work with DSP and proper HP filter. ScanSpeak Revelator 18W/4531G 7" Mid-Woofer 4 ohm
Scanspeak Revelator (yellow) vs AF GS60 (blue) vs AF GB60 (purple)
Rectangle Product Slope Plot Font
294693
· Registered
Discussion Starter · #6 · (Edited)
I would like to model the Anarchy-704 and Fi Audio N.7 but they do not publish their TS parameters so if anyone has them then please post them here so I can model them.
Reactions: bnae38
· Registered
Discussion Starter · #7 ·
Next up is the is the Peerless SLS 830667 8 inch driver from Madisound. This driver is not made for car audio but with proper rain guard could work out well because of its friendly IB TS parameters. It has an fs of 42 Hz and a total Q of .66. The price on this driver is low at $55.52 each. This could be a good budget option for a three way system. Peerless SLS 830667, 8" Paper Cone Woofer
Peerless SLS 830667 8 inch (red) vs AF GS60 (blue) vs AF GB60 (purple)
294695
You will need to implement a proper HP filter to avoid exceeding excursion with this driver and it is rated for 90 watts RMS and I used 70 watts in the model so everyone could compare to above.
294696
Reactions: 96jimmyslt
· Registered
Discussion Starter · #8 · (Edited)
Next up is the Morel MW166-4 6 inch woofer from Madisound. This driver is not made for car audio but with proper rain guard would work out well because of its friendly IB TS parameters. It has an fs of 45 Hz and a total Q of .46. The price on this driver is a modest $138 each. This could be a good budget option for a three way, or two way system. Morel MW166-4 ohm 6" Woofer Damped Polymer Composite Cone
Morel MW166-4 6 inch woofer (red) vs AF GS60 (blue) vs AF GB60 (purple)
294697
You will need to implement a proper HP filter of at least 80 Hz to avoid exceeding excursion with this driver. I used 70 watts in the model so everyone could compare to above.
294698
· Registered
Discussion Starter · #9 ·
Next up is the is the Morel Hybrid MW6 MKll 6 inch woofer from Crutchfield. This driver is made specifically for car audio. It has an fs of 45 Hz and a total Q of .44. The price on this driver is high at $499 per pair. This could be a good high end option for a three way, or two way system, and you know it is specifically made or IB car audio use although the TS parameters are not he most ideal for that I guess. Morel Hybrid MW6 MKII Hybrid Series 6-1/2" woofers at Crutchfield
Morel Hybrid MW6 MKll 6 inch woofer (red) vs AF GS60 (blue) vs AF GB60 (purple)
294701
You will need to implement a proper HP filter of at least 80 Hz to avoid exceeding excursion with this driver. I used 70 watts in the model so everyone could compare to above. As you can see even drivers specifically made for IB use can exceed xmax without an HP filter. This driver is not meant for the novice who may not know this.
294704
· Registered
I would like toe model the Anarchy-704 and Fi Audio N.7 but they do not publish their TS parameters so if anyone has them then please post them here so I can model them.
Fi used to have specs listed for them. It's possible they were removed in error.
· Registered
Discussion Starter · #12 · (Edited)
@bnae38 Here is the Fi N.7 7 inch mid-woofer from Fi Audio. This driver is made specifically for car audio as well by Fi Audio. It has an fs of 53.2 Hz and a total Q of .49. The price on this driver is a very budget friendly $160 per pair. This could be a good high end option for a three way or two way system. They also list this driver as having a copper pole piece for reducing inductance however I was not able to get that number accurately so I guessed. I used .3 Le (inductance) for that number which is I think about average for a driver like this. Many of the features found on this driver are not usually found on a drivers that only cost $160 so this is a rather unique driver, and a bargain at this price.
Fi N.7 7 inch mid-woofer (red) vs AF GS60 (blue) vs AF GB60 (purple)
294739
Like most smaller mid woofers you will need to implement a proper HP filter to avoid exceeding excursion limits with this driver although this one does quit well assuming it actually has 10 mm of excursion. I used 70 watts in the model so everyone could compare to above.
294740
· Registered
Discussion Starter · #13 ·
Next up is the Peerless by Tymphany 830946 6-1/2" driver from Parts Express. This driver is not made for car audio but it has been used successfully in the past as a dedicated woofer in a three way system, or small subwoofer in an enclosure. It has an fs of 42 Hz and a Qts of .35 so it is not the best for IB use going just by the numbers anyway. The price on this driver is low at just $56 each. Home
Peerless by Tymphany 830946 6-1/2" (red) vs AF GS60 (blue) vs AF GB60 (purple)
294744
Cone excursion and xmax on this driver is quite good so it should do well but you still should use a HP filter or limit the power you put on it.
294745
· Registered
Discussion Starter · #16 ·
I wonder if some of the sb acoustic drivers are worthy of being tested?
Yes but they have open coil designs so they would need to be implemented with proper rain guards. I ran the Sb17 variant years ago with good success. Those are coming next a little later on (likely tomorrow).
· Registered
I believe the anarchy's are still produced close to the original ts specs
I have a dats and some 4ohm models sitting here. I checked them quickly and they matched up pretty well, IIRC.
· Registered
2015 S60 T6
Anyone have any experience with this guy? Looks like a great speaker at an even better price, so how come there's no talk of it?
1 - 20 of 146 Posts
