101 - 120 of 146 Posts
· Registered
Next up are three 6x9 contenders I think everyone wants to see together. The AudioFrog GS690 vs the CDT 6x9 vs the Morel Temp Untra MW 6x9. All of these are designed for car audio and are intended for use in two way or three way systems. The fs for the AF is 58.3 Hz, CDT 52 Hz, and Morel 52.64 Hz. The Qts for the AF is .649, CDT .568, and Morel .40 and all are suited for IB use. Inductance is as follows AF .18 mH, CDT .63, and Morel .36 mH. I used the ts parameter from @SWRocket , post #62 for the CDT and they seemed to work out although the cone displacement was kind of low.
CDT (red) vs AF GS690 (blue) vs Morel Tempo Ultra (purple)
Cone displacement on all of these are very similar at 70 watts.
I feel as though AudioFrog is the one to beat in all of these comparisons. Maybe I should just pull the trigger on a set.
I am curious how the Audison AP-8's would model. Seem extremely affordable for 8" midbass. I see them listed from $249-$299 a pair.
I'm curious about this as well. I like the idea of an 8" in a 2 way system for some odd reason....
· Registered
Discussion Starter · #102 ·
An 8” for a two way with tweeter is not a good idea mainly because the larger diameter speaker runs into beaming early which makes the higher frequencies drop off and the tweeter can’t cross low enough to make up for it. The Audiofrog GS690 with GB15 does work well so I would say that is somewhat an exception.
· Registered
They'll be used in a 2 way with widebands (CDT ES2EX) in pods crossed at 500....
Sent from my SM-G781V using Tapatalk
· Registered
Discussion Starter · #104 ·
In that case your all set. 👍
· Registered
Discussion Starter · #106 ·
Yes, but I think I have to use a different computer or use BassBox Pro in safe mode to make it work.
· Registered
· Registered
Got a request and specs for the Dayton Audio Epique E180HE-44, when you can get things working right again.
  • Piston Diameter = 132 mm
  • f(s)= 42.932 Hz
  • R(e)= 6.6502 Ohms
  • Z(max)= 45.979 Ohms
  • Q(ms)= 3.9691
  • Q(es)= 0.67114
  • Q(ts)= 0.57407
  • V(as)= 10.826 liters (0.3823 cubic feet)
  • L(e)= 1.6225 mH
  • n(0)= 0.1217 %
  • SPL= 82.953 1W/1m
  • M(ms)= 33.391 grams
  • C(ms)= 0.412 mm/N
  • BL= 9.4473
  • K(r)= 2.8753
  • X(r)= 0.14338
  • K(i)= 0.0005886
  • X(i)= 0.91977 *
Reactions: Picassotheimpaler
· Registered
I second the epique. Super interesting driver.
I think I may wana make a set of home towers with a couple of these. Just unsure as to what home amps could comfortably power them lol
They don't like 300 watts, they get a little smelly, but I clipped that 300 watts, so a clean 300 might be ok. They definitely don't bottom out like the Anarchy's.
· Registered
2017 Toyota 86. Focal Utopia M, Audiofrog GB, Mosconi Zero
Xo at what point w/ 300w without bottoming them out? That's just crazy impressive considering how high they are still able to play.
· Registered
That was 87 hz low pass running as subs, haven't gotten around to pairing them with tweeters to try a 2-way yet, it requires hooking up a different amp so I don't have to retune my current setup.
They are impressive as subs.
· Registered
I've heard they actually do quite good in the higher octaves as well. So if they actually follow up on that promise too, that's unreal.
· Registered
What size box were they in?
0.14 cubic foot modified 6x9 prefab boxes, heavily stuffed. Not optimal, but they are the boxes that I used for the Anarchy's. The Dayton's model nicely for a 0.25 cubic foot box, each.
Reactions: SiW80
· Registered
Can I make a request, I’d love to see how the JBL 660/670GTI midbass drivers compare to some of these drivers. I don’t think Harmon ever made a better car audio specific woofer.
Apparently, their lowest distortion spec driver EVER.
I just moved my pair from e30 convertible 3 way duty (88-444Hz) to my daily 2 way setup in the 05 Tc (80-2800Hz). Tuning was super easy(Ms8), and a MUCH better improvement over the Silver Flutes!
I can tell there is less distortion at high volumes. Vocals are clearer. MB seems more solid.
