So basically the setup is a sundown sa15 on an ignite audio 6000d1. It’s 1100 watts rms driven off a cheap dual head unit. 4 gauge Rockford fosgate ofc wiring with sound deadening in the trunk. Hooked up in a crown Victoria p71.
After vigorous testing and tuning and restarting and months of trying to find a spot where I’m content with the sound it’s just not enough. 40-45 hertz only hits 130 dB and anything lower just rolls off. The box measures 4.3 cubic feet (assuming my math and measurements are correct) with no bracing. The box shakes like absolute hell to the point where when you pop the trunk it’s most of what you hear. Everything that I saw on these subs tells me one on 750 watts should play at least 140 decibels which is twice as loud 3 times. And I’m running it on 1100 watts so any help to get louder would Be appreciated.
Mostly curious to know if the prefab box from the electronics store is to blame or the head unit or maybe both?
I ran a single mtx 15 in a 2.5 foot ported box that hit a lot harder and flexed my entire car on 600 watt boss amp and this system barely bounces my trunk so I’m absolutely confused. Any advice is appreciated
