Upgrade for 2001 Nissan Sentra GXE.
510 Views 3 Replies 2 Participants Last post by  dasupr3mek1ng
I'm starting this one now so that I can document the entire process from brainstorming to final form.
The current build:
Android 10.1 HU
Clarion EQ 755
Dayton DSP
Fully active front stage:
Hertz Dieci DSK 6.5 components
Hertz Dieci 87.3
Taramps TS 400x4, 63 watts rms per channel
Rear fill:
H,ertz Dieci DCX 165.3
Sub stage:
(4) DC Audio Level 1 12's wired to 1 ohm
Taramps Bass 1200.1
5 cubes net tuned to 32hz
Current electrical:
60ah AGM car battery
250 amp alternator
Big 3 with 2/0 welding cable
2/0 throughout and 17 ft run to rear.
Pics:
Automotive exterior Automotive tire Bumper Automotive wheel system Electrical wiring
Audio equipment Wood Chair Automotive design Metal
Car Speedometer Vehicle Gear shift White
Electrical wiring Cable Ac adapter Electronic device Computer hardware
Gas stove Cooktop Kitchen appliance Record player Kitchen stove
Vehicle Car Hood Steering part Motor vehicle
The current plan for upgrades:
New 10.1 Android HU
Clarion EQ 655
Helix or Mosconi 8 channel minimum DSP
Front stage upgrades:
Hertz Mille Legend 165.3 components
Hertz Mille Legend 700.3 3" mid-range
Rear fill upgrades:
Hertz Mille Pro 6.5' 2 way coaxials
Sub stage upgrades:
4 DC Audio Level 3 12s
5k amplifier
Net 5-5.5 cube enclosure tuned to 33hz. Double baffle 3/4 MDF
Electrical upgrades:
320-370 amp alternator
2nd run of 2/0 to rear. Both runs direct from alternator.
Add 2nd ground from alt to battery
12 volt 96ah headway (convert 24 volt, 48ah beast)
I think I wanna go with higher end amps given that I'm upgrading to Mille Legend. I want to be able to show them when the trunks open.
I'm open to ideas. They need to fun at least 100 rms for 4 channels and at least 80 rms for the other 4. And offer a matching 5k option.
Given that this is still in the planning stage, I'm open to options and any feedback. The goal is to take what I've learned so far and improve.
Lewis King
Gladen RS 100C4 4-Channel 600W RMS RS Line Amplifier (woofersetc.com)
Gladen SPL-5000c1 LV Monoblock 5000W RMS SPL Line Series Class D Amplifier (woofersetc.com)
That desire for a matching 5K is going to hamper what you're trying to do in my opinion and you'll run into a situation like this where having big power from a quality set of amplifiers is going to cost an arm and a leg. That said, what I've linked lines right up with what you're trying to do. After that I think it's a situation where you look elsewhere for not quite as "high end" amps.
You also could always find some dope amps that can feed your front and rear stage with good power and are higher end and just try to match colors with a more SPL specific amp setup...(i.e. these 2 Gladen 4 channels and a Sundown Salt 4 which really puts out 5k on the dyno, they also offer another Gladen 4 channel that offers higher power in 4 channels but for more money Gladen XL 150C4 4-Channel 900W RMS XL Series Amplifier (woofersetc.com) )
Sorry if it doesn't offer much help on that end, figured I'd try.
Reactions: 1
Dude that's awesome. And probably the way that I'm going.
FYI one Taramps TS 400 blew. They offering me a trade in on the ts 800 with credit but I'm gonna let that go.
Also ...
I took apart the window motors and fixed them. They're still working as of this post.
I'm down to 6.5 in the front. The amp that blew was the one with the 3.5 and the tweets. Still sounds decent though.
The box is done for. It's leaking out of every side, every joint, the port... Dude it's bad. I can't build another for the moment though because I'm moving. The bass and the rattle be having a sound off. I have to keep it at 25 percent or.... Rattles.
  • Sad
Reactions: 1
