Hey all...been a minute since I've posted, but I've got a question maybe someone could help me with.
I know hi/lo converters are used to convert speaker level connections into RCA connections. My question is...can the same unit be used in reverse (RCA to speaker level)?
I ask this question simply because with some OEM systems, there's an external amp being used. Running the regular speaker outputs from an aftermarket HU would be sending a signal stronger than the OEM HU was producing to the OEM amp, in turn...creating a situation for distortion to be created really easily.
I was thinking the low level outputs could be utilized in a set up like that, then you wouldn't have to worry about, right?
Feedback is greatly appreciated.
