Thanks for the input. I've seen that suggestion, but I am looking for wire polarity, not the speaker polarity.
This is what I've got:
wire loom along floorboard was tapped for left rear and right rear speakers to be used as high level inputs
the wires that I added are run under the carpet to the amp location
those wires are unlabeled
the rear door speakers still work, and when I connect a test speaker direct those those wires I've run to the amp, it plays just as the door speakers do (polarity is not an issue here)
however, I need to connect the left and right rear +/- to the appropriate polarity on the high level harness provided with amp
can I use a multimeter to check those bare wires, prior to splicing to the high level input plug, potentially while music is playing (or otherwise)?
