1 - 16 of 16 Posts
Alpine H800 and C800
Good Used Condition
I do not have the original box for the H800 but I do have the original box for the controller. There is a small scratch on the H800 that can be seen in the pictures. The original mounting brackets are not included (since I do not have them). You can see the L brackets that I used (they are silver instead of black) and they are included.
$450
Included
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Pictures are broken
For some reason when using your phone to view via tapatalk, pics hosted from photobucket don't seem to always work.
But here they are again...
Bump
Nope
bump
I have been asked by several people what is the difference between the H800 vs the H701. So here are a couple of links I have found that outline the difference between the two units.
http://www.diymobileaudio.com/forum/general-car-audio-discussion/105910-ridding-h701-just-get-h800-why.html
Hi Guys,
A few quick corrections on things.
Fully Manual Tuning built-in ... a la F#1 Status and H701
Dual Optical Input + Ai-Net Input + Ai-Net Aux
Ai-Net Connection to INA-W910 - Preset, Sub Level and Balance/Fader
Tuning is done via the new RUX or the PC Software
6CH Input (RCA or SPK Input - Up to 10V Input) / 8CH Fully Active Output (4V Output)
- In fact, our CES Demo Car is running an 8CH Active 4-way setup w 2x1" TW, 2x5" Mid, 2x8" Front Sub, 4x12" Rear Subs)
Improvements over the H700:
Huge Signal-to-Noise Improvement - 110 Digital / 105 Analog
Increased Channel Separation - 90dB
Significantly More Powerful Manual Tuning
(+/-12dB for all bands vs. 9dB)
10 Band Parametric for Front Rear and Center (vs 5)
5 Band Parametric for Sub (vs 2)
Includes ability for 36dB XO Slopes
-24dB to 0 Level Control (vs -10dB)
Yes, it has ImprintEQ built in, however this is a totally new tuning process compared to the previous Imprint It is significantly more detail in its resolution/measurements, especially in the mid and LF range. This allows us to tune that area with a lot more detail and accuracy. On top of that, you guys will be able to choose from 3 Alpine defined target curves, as well as set your own target curves (drag and drop in the PC software) to auto-tune to your tastes. You'll be able to tune to your taste, either by full manual tuning, auto-correction or auto-correction + your own manual turning.
It is designed to work in both OEM and ultra-high end AFT system, with the ability to manually or automatically to satisfy pretty much any tweakophile.
More to come later ... :D
Jim (from Vegas)
bump it up
Discussion Starter #12
Does it come with the mic?
Yes, it does. I was working on replying to your pm. I took more/better pictures earlier today. I will pm them to you.
You get my pm?
Discussion Starter #15
pending
Discussion Starter #16
And SOLD!!
1 - 16 of 16 Posts
