I was thinking of epoxying the baffle or frame (if it must sit up higher than the floor) to the trunk metal, full seal, and rubber caulking as well.
if the midbass were in the rear, it would have its own airspace, NOT share airspace with the sub, basically two enclosures sitting next to each other in the tub. I am thinking the rear because I cant find space up front, at first I thought there was a cavernous area under the shifter in the dash, but its completely filled with electronics, and I dont want to cut into the doors. the rear speaker areas would be ok, but then I would need two drivers, and that increases cost, plus I am only running an 80w single channel, though it may very well be 2ohm stable (or I could get 8ohm drivers) so I COULD run them both off that.
I want to run seperate midbass and midrange because I want my drums to kick me hard, I love that particular aspect of live music and I want my car to do it well, the sub I currently have does NOT do it, and a sub should really be for 80hz and below, doesnt play the drums tight enough. plus, I have a 4ch amp with summed 5th, and will be running the midrange/tweets off the 4ch bridged to 2ch, and I figured that sum channel would work well for midbass since it has its own xover, and the sub amp only has one xover (for two channels that I currently have bridged to mono).
