1 - 11 of 11 Posts
Model 73-46 Vanner Heavy Duty Automatic Throttle Control System
MSPR $342.00.
Comes with auto throttle solenoid and all relays. This was purchased to install on a SPL built vehicle to automatically bring the truck to 2000 RPM's with the push of a button. It was never installed in the vehicle, as you can see from the airplane cable, there are no kinks in the cable where the clamp will go. I have verified that solenoid does work correctly. Solenoid was packed away in a tote for a couple of years, so there is a little bit of wear on the label.
Any questions please pm or email me at [email protected]
Like new
$150 Shipped
Included if shipped within the US
WOW no offers. Thought there would be more interest on this item. My dealer cost is $215. Great Deal at $100. Will sacrifice at $60 + shipping. Just looking to recoup some money and try to clean up the garage. Thanks for looking
Super Moderator
Never even seen one of these before. I assume this can be made to work with any vehicle that has a cable throttle connection?
Discussion Starter · #8 ·
Yes. What it does is simply run parallel with your throttle cable. At the end, it will use a compression type H connector to mate with your factory throttle cable. After some adjusting, you can apply power to the coil, thus putting the throttle in what ever position you set it up for ie. 2000 RPM. They were popular a few years back here locally, not sure if they are allowed to use them in a IASCA event. They would be installed on a vehicle that was in a SPL type competition with a external head unit setup. This would allow them to hit a switch and put the throttle up to 2000 RPM ( amount allowed varied by event) from the outside of the vehicle, so when the "burp" came the voltage and current to the equipment would remain somewhat stable with the load.
I can also see this being used in a custom install to push or pull a load. More specs here for those whom may be interested...:D
http://www.vanner.com/wp-content/uploads/2010/07/AutoThrottle-Owners-Manual-6-98.pdf
Check your PM box.
1 - 11 of 11 Posts
