SPEAKER:
Coral Audio Component PRF165 and PRF25 tweeter - $120
https://www.rgsound.it/prf-165_coral-electronic-id-845.html and https://www.rgsound.it/prf-25_coral-electronic-id-843.html, both retails for 210 Euro. Italian brand, good for louder SQ component. As you can see the magnet is huge for 6.5 midbass. Much better option than you regular "Sony/Alpine/Pioneer" speaker. The brand is comparable to Focal/Morel/DLS. Will come with tweeter pods. Missing 1 passive crossover, if I can find it, it will come with both crossover. You can run it active with CalCell amp listed below.
Pair of Digital Audio 6.5" midbass/subwoofer DAMD60 - $80 for the pair (2 pcs)
Big magnet, good for SQP or SPL. Specs: * Power Handling: 200 watts RMS * Frequency Response: 35Hz – 5kHz * 30oz. Strontium Magnet * Laminated Glass Fiber Composite/Pulp Cone * EPDM Rubber Surround * 2 Layer High-Temp ASV Voice Coil * 3 ohm Impedance * Sensitivity: 93 dB
CDT CL-42 - $180, brand new in box (not in picture)
Bought it for my gf's bmw, ended up with different direction. Good 4" component setup.
AudioFrog GB15 - $300
Barely used, less than 5 hours of use. I bought this as a kit with AudioFrog GB60. I ended up using different tweeter.
Hybrid Audio Clarus 6.5 compoent - $480
Midbass is brand new in box, tweeter is used for demo, less than 5 hours of use. Can't ship this item until 3rd week of October.
Phoenix Gold RSD65cs - $80
Good working condition.
AMP:
Calcell 5 channel amp - $150 (big black amp)
Taken out from my car end of last year, retailed for ~$300 on 2006. Rated at 60x4+150 @ 4 ohm, [email protected] ohm. Channel 3&4 are bandpass capable.
Soundstream Picaso Nano PN4.520D - $80
Used, working fine. Not the best cosmetically though. Cheap and small amp that do rated.
ARC Audio KS900.6 - $350 - PENDING
Good working condition, tested and all ports cleaned. Cosmetic is not perfect, but in good condition.
LM Audio Amplifier 2k Monoblock - $230 - PENDING
In really good condition. No bass knob. Should be able to do 2k @ 1 ohm easily. It has 160A internal fuse, should be comparable to SAZ1500.
Sierra SRA 800D Monoblock - $100 - PENDING
Used in perfect working condition, taken out of my car end of last year. Rated at 600w @ 2 ohm at 12.5v, 1 ohm stable. Korean made amp. Distributor told me its a the factory which manufacture amp for lots of "higher end" brand name, they just make their own brand. Should do rated, fuse is 80A, so should be doing [email protected] at 14.4v.
OTHER MISC ITEMS:
AudioControl Four.1 pre-amp - $100
Used, in good working condition. Not the prettiest, but working just fine.
AudioControl EQL - $125
Good cosmetically and perfect working condition. 2 channel eq.
Rockford hi lo converter $10
BNIB
Yamaha HPH-MT220 Studio Monitor Headphones - $150
Still have original box, played it in mid volume for 150 hours to make sure is fully break in. Audiophille grade headphone.
Mosconi DSP bluetooth module $40
Used, not using it because my car has bluetooth anyway, and I play directly from USB cable.
Hifonics MX3 - $50
Brand new with manual and bass knob, no box. Bought it in 2010, planned to use it but ended up just sitting in storage.
Everything is used, in perfect working condition (unless noted otherwise, ie CDT and Hifonics are brand new)
Will do package deal for multiple items
You pay shipping, negotiable.
Close up pics for each item can be found here (some are sold/pending items):
Amp by Wilson Gautama | Photobucket
Looking for sale only, the only trade I might entertain is for SQ items:
1. Amp (Mosconi/Zuki/other hi end) - but I am not looking to add cash, so you either trade for more items for your high end SQ amp
2. Hi sensitivity coax that I can use with stock head unit, 6.5" or 6x9 coax. Not super expensive coax though, probably something worth $100 or less.
Please note, those are asking price and I will entertain reasonable offer. Please respect my time (and yours too) and do not lowball me. I might be a little off on price for a few items because I haven't check car audio community for a while.
I'm located in Lynnwood, WA (a little North of Seattle) for local sale. I can meet up somewhere within reasonable distance. I will do package price if you are buying more items.
Let me know if you have any questions.
Let me know if the 900.6 falls through...
