I've been thinking about and simulating box sizes for my next sub setup. I like the simplicity of IB, and I was thinking I'd try my infinity perfect 12 that way, but vented looks so apealing also, but the box needs to be sooo big.
Then I thought why not use the whole trunk as the box? you would have to seal it up real good and things would change when the trunk is open and add have stuff in the trunk, but I have an EQ for that. I figure I'll have about 13 cu ft of trunk space.
Heres a WinISP pro model:
All have a 20hz 4th order high pass and are running 150 watts. The white is 13 cu ft tuned to 18hz with a 20hz 4th order high pass. the red is the same port size, but 500 cu ft (trunk open). the yellow is the same driver IB.
So, what I'm seeing with my trunk open it will act like its IB.
Any thoughts? I'm guessing trunk preparation would be key to making this work.
