Veritas Aluminum horn bodies with 1" adapters, 1.4/1.5" adapters, and 3D printed 1" straight adapters.
Used, mounted, trimmed.
$400
Split shipping, I'm in Canada. Will be approx $20 based on past experience.
As you can see, the bodies have several layers on B-Quiet dampener on them, and the mouths were spray painted flat black. They were slightly trimmed on either end.
I have never seen a pair of these for sale with the 1.4/1.5" adapters, these would be awsome paired with a set of JBL D2 compression drivers.
I also had a set of straight entry 1" adapters made from shapeways.com. They cost me $180 if I recall correctly. One adapter still needs the mounting holes drilled out.
I'm going to peel off the dampener when I get a chance, I have some spare Dynamat I'll stick on them to clean them up a bit.
