1 - 5 of 5 Posts
Yes, if you don't mind that both sides will be in mono.
Ok, for subwoofers, but not if you want stereo.
( at least i think that's the way it will work .... 馃槣 )
Not sure. I under stand... if it鈥檚 a pass through and I use left and right RCA cables to feed from 1,2 to 3,4 Shouldn鈥檛 sit be stereo.
Channel 3,4 are my front tweets and 1,2 are brigade for the Subwoofer. this is the second amp being feed from. a pass through on an Alpine amp So, HU, TO Alpine for Door 6" Mids, and 6x9 rears. And then pass through to the VIBe for the Tweets and the Sub.
Well that is not the diagram you presented, which is a dual bridged mode.
Your three channel mode suggestion should work just fine as long as the pass through is not outputting a crossed over signal.
Thank you
1 - 5 of 5 Posts
