1 - 8 of 8 Posts
I replaced the 4 inch mids of my CDT 642 3-way set with a Vifa PL11WH09-04. The midrange is greatly improved. What are the thoughts on this series? I am considering replacing the 6.5's as well. The basket of the vida 4 was identical to the CDT, the magnet was much heavier. My set was bought in 2002, I noticed that the new CDT set has the same magnet weight as the Vifa I just bought.
DIYMA Founder
I think you will be much happier spending a little less money than the Vifa Pl and replacing your cdt mid with a Seas CA18RNX. :)
Seas are cheaper, more detailed and open sounding, and the bass is punchier/snappier.
okay I pmed you I need to hear more about this vifa 4.5" it does look real close to the cdt one lol
heres the A/B parameters of the VIFA to CDT 04 ???
VIFA
Nominal impedance [ohm] 4
Voice coil resistance [ohm] 3.0
Nominal power [W] 35
Short term max power [W] 140
Long term max power [W] 80
NR surround
Sensitivity [dB] 89
Frequency range [Hz] 70-5000
Free air resonance [Hz] 67
Voice coil diameter [mm] 25
Voice coil height [mm] 10
Air gap height [mm] 4
Voice coil inductance [mH] 0.31
Eff. diaphragm Area [cm²] 58
Moving mass [g] 6.4
Magnet weight [g]/[oz] 415/14.6
Force factor [Bl] 4.7
VAS [l] 4.25
Qms 1.80
Qes 0.36
Qts 0.30
CDT 04 4.5" ( 5" around)
Long term max power [W] 100
Sensitivity [dB] 89
Free air resonance [Hz] 54.3
VAS [l] 7.52
Qms 3.51
Qes 0.29
Qts 0.27
Sd 58 cm²
Bl 4.58 T/N
Rm 0.53 Ns/M
Re 3.3 ohm
Md 5.42 grams
The specs for the CDT 4 you have are actually for the old CDT 4". CDT never updated their specs. These old specs are nearly identical to the vifa pl11wg09-04e. I suspect that CDT had trouble with these (I did) and went up to the PL11WH09-04. Notice that the magnet weight listed for the new CDT 4 is the same as the PL11WH09-04.
DIYMA Founder
Ah I'm sorry I thought you were talking about replacing the 6.5" :)
The vifa pl11 mid is actually a pretty good driver, if not a bit on the warm side. It's certainly a very dynamic and beefy driver as far as a 4" mid goes.
Vifa pl is definitely for those seeking a rich, warm, dark, softer sound Imo.
regal said:
problem with the seas CA18RNX is it is 8 ohm. I only have 75 wpc @4 ohm, 8 ohm would drop it down to 37.5 wpc. What about the Seas lotus series?
Those mids should play fine off that much power. Have you read this thread yet?
http://www.diymobileaudio.com/forum/viewtopic.php?t=33
Pretty big price difference between the Lotus and the CA18RNX. Either choice will be good though. Just depends on how much you want to spend. I'd try out the CA18RNX. If you don't like them they should be easy to resell.
1 - 8 of 8 Posts
