So you only have two channels of amplification and don't have the budget to go active?
I went passive with some cheap components that I was able to find some decent FR graphs for (with Seas or Morel decent specs, freq response and impedance graphs can be found pretty easily, the peerless drivers I chose it was a bit tougher). I used spl trace to trace the graphs and then used some free software (PCD - passive crossover designer) by Jeff Bagby (can be found on techtalk.parts-express.com quite frequently) and worked up the approx acoustic rolloff I was looking for (4th order LR). It's a little harder to get good summation by just designing when working with car audio because of all the variables (lots of reflections, positioning may not be completely known before hand, so you don't know acoustic offsets, acoustic offsets may be entirely ridiculous etc).
If you had measurement equipment, you could get the drivers into the vehicle, measure them then design using those measurements.. that would yield better results, but more cost in measurement equipment (which could be used towards going active).
Also, if you know the drivers or at least one and are flexible on the other you could use someone else's design and just remove the baffle step compensation from the crossover (if there is any). The are plenty of already designed 2-way speakers using seas and morel drivers.
