Where are the passive radiators?I hid that one, they basically look the same, but the lower tuning requires a 6 foot long port.
Dude - I tried to figure out how to fit twin 18 PRs (2x15 PR was not enough excursion for 2x12SQL Active) in a 2.2 cuft box and there's simply not enough space inside the box.Where are the passive radiators?
I never model those, since most people don't need them, if they do need them someone else can model it.Where are the passive radiators?
A 6 foot port seems like it needs some space too.Dude - I tried to figure out how to fit twin 18 PRs (2x15 PR was not enough excursion for 2x12SQL Active) in a 2.2 cuft box and there's simply not enough space inside the box.
Oh it does and that's the reason the 15s work better (easier?) ported than the 12s. I've yet to have anybody tackle the 12s ported in a SQ alignment - they always end up sealed or ported at 32 Hz.A 6 foot port seems like it needs some space too.
Do they go sealed or ported @32 because that is where everyone does it?Oh it does and that's the reason the 15s work better (easier?) ported than the 12s. I've yet to have anybody tackle the 12s ported in a SQ alignment - they always end up sealed or ported at 32 Hz.
I've designed two different boxes for 12s ported (a single and a dual) but in both cases they went sealed.
Sealed cause they found out that the output they wanted was plenty with sealed.Do they go sealed or ported @32 because that is where everyone does it?
or because that is where it sounds best?
And the driver also has a preference for sealed or ported?
My main point was that if someone is going ported, and they have a 6’ Howitzer barrel to keep it from chuffing, and they are also unsure of the port tuning freq… Then the only rational answer there is, “PASSIVE RADIATOR”.
Have you considered using a PR?The SQL12 "wants" 1.358 cuft tuned to 25.5 Hz (F10 = 19Hz) but porting a box that small that deep results in the port volume taking up more space than the enclosure. The port needs to be 6" Diameter x 81" Long...
Raising that to 32 Hz but keeping the box size the same results in a 50" Long port and a +3dB hump in the response at 37 Hz with F10 of 22.5 Hz - the bigger the box gets from this the bigger the hump becomes.
By the time you get to 2.5 cuft and 32 Hz (25" port length) the peak becomes +6dB at 34Hz with F10 of 23Hz.
Major Boom Box by this point... but if all you want is maximum boom and you're used to the 40-42Hz prefab boxes with Skar Subs then you'll be very pleased as the SQL stomps on them in this situation. I've put SQL12s in prefab boxes purchased from Amazon and had very pleased teenage boys booming away in their squatted trucks. All of this is why we keep looking for ways to make a Passive Radiator work, the SQL12 is simply tailored to such small enclosures that there's not enough baffle space for the PRs.
Here's an example of a properly tuned Ported Enclosure for the SQL12 - this is a top-down cut-a-way view of the enclosure that's 14" tall (1.2 cuft at 26.6 Hz Slot Ported) so it's not impossible to do correctly:
How is a PR not a ported box?No I want a ported box.
