At the recommended 1.5ft^3 @ 24Hz (20in^2 x 58.43"), SQL-12 vent velocity is a much more reasonable 33m/s. Response is very nice as well ...58.43" port, not so much. PR seems like a sensible option.I was surprised as well. Might be a typo for the 15". The 15" HST is asking for 50in^2 but so is the 18" HST so thats weird as well....
Go back to looking for a 15" - the SQL12 in the box you're looking at with the power level you've got will not be good.Thank you for that Grinder. It won't hurt anything to have a big peak around 35hz right?
If you care about SQ, it will. You'd have to EQ all of that peak out, plus all the cabin gain in that area as well. @daloudin is trying to tell you that this sub is not well suited to your application, and in my far-from-expert opinion, I agree.It won't hurt anything to have a big peak around 35hz right?
Please post screenshots of any models.So I modeled the Stereo Integrity SQL 12" sub with 2ft3 tuned at 32hz against my TC Sounds LMS-R Ultre 5400 18" sub tuned at 20hz in a 7ft3 box with 1,000 watts to each sub. At 30hz the SI is at 115db. And the LMS-R is 118db. At 50hz the SI is 115db and the LMS-R is at 117db. Looks pretty good to me! The LMS-R is in my home theater.
Why is that?Not even remotely in the same class as the other 2.
Ctrl + Alt + PrtScr while WinISD is selected will take a screenshot of the WinISD Screen you are viewing then Ctrl + V in the forum comment box will paste that screenshot.I don't know how to post screenshots of winisd.
Dayton Audio subs are a "bang for the buck" item with good/great sound quality but do not have the spl capability of SI or Sundown.Why is that?
The Specs of the Dayton RSS390HE-22 seem right up there with a SQL 15"Dayton Audio subs are a "bang for the buck" item with good/great sound quality but do not have the spl capability of SI or Sundown.
Please get one and put it on about double RMS so we can find out...The Specs of the Dayton RSS390HE-22 seem right up there with a SQL 15"
27mm XMax
800 RMS
Double spiders
These are a bit more robust than previous Dayton subs like the HO or Ultimax..
SQL15D2 | HE15D2 | Brahma15D2 | |
Price | $400 | $360 | $550 |
Fs | 23.8 Hz | 29 Hz | 24.4 Hz |
RMS | 1,000 Watts | 800 Watts | 1,000 Watts |
Sealed 0.7 Qtc | 2.3 cuft | 3.0 cuft | 3.5 cuft |
Output Peak Non-Anechoic | 114.340 dB | 112.925 dB | 114.629 dB |
Output at 20 Hz | 104.5 dB | 103.0 dB | 104.4 dB |
I already got a pairPlease get one and put it on about double RMS so we can find out...
Modeling done in WinISD to RMS Rating:
SQL15D2 HE15D2 Brahma15D2 Price $400 $360 $550 Fs 23.8 Hz 29 Hz 24.4 Hz RMS 1,000 Watts 800 Watts 1,000 Watts Sealed 0.7 Qtc 2.3 cuft 3.0 cuft 3.5 cuft Output Peak Non-Anechoic 114.340 dB 112.925 dB 114.629 dB Output at 20 Hz 104.5 dB 103.0 dB 104.4 dB
The HE15D2 is between the SQL15 and Brahma 15 in box size - I've heard all 3 in person, though not in the same vehicle but in appropriately sized sealed enclosures on appropriate power and been allowed to tune on them and IMO none of them are a bad choice - it all comes down to what you need. If you're trying to save money then get the Dayton, if you need the smallest box and the absolute most output get the SQL and a big amp, if you want efficiency and SQ above all else and have room for the box on the Brahma - well there you go.
My only reservation about the Dayton is long term reliability - not sure what will happen when someone throws 2-3kW on it in a Daily setup and pounds on it for a year. The one I played with was on a Pioneer GM-D8701 with only OEM factory electrical and a Belva 4 Gauge amp kit, it was dimming some and with the teenage son that he has, I'm sure that poor thing will get clipped to death. The Brahma I know for a fact will have a meltdown on 2.4kW (BTDT) but the SQL12 in my current setup shrugs off the Taramps 3k (IMO the equivalent of a 1kW Class AB) and I've seen a Dual SQL15 on SALT6k (that's abused way more than mine) that has survived during the same time period (just over 12 months now.) With that said, I've abused other Dayton Reference Series Subs and never had one meltdown yet (bottomed the cone on a pair of 10HF's till I just knew it was deformed but it survived) but the HE is a totally new line and with an Aluminum cone and former it should be able to dissipate some heat so only time will tell.
I stand corrected, never seen a Dayton sub with that much Xmax. I'd still opt for SI.The Specs of the Dayton RSS390HE-22 seem right up there with a SQL 15"
27mm XMax
800 RMS
Double spiders
I've looked at doing a 2 x 15 ported for the son of my cohort who has the 2 x SQL15 on SALT 6K but with a Taramps Bass 5K he's currently using on a Skar Prefab 2 x 12 EVL Box setup he's got major dimming so he's saving up for electrical upgrades right now...I already got a pairbut trying to decide If I want to run them sealed to save space or take up all my cargo room and go ported.. They will be going in a SUV.
