1 - 20 of 165 Posts
I want the other thread to get buried as it mentions the tweeters, and they are definitely not the problem...
Equipment is Fiio X5 (digital) --> Helix Pro Mk2 w/Director --> Zapco st 4 channel and mono --> GB10s, GS690 & GB12s
NO ANALOG SOURCE TO THE DSP, ONLY THE FIIO. THE DIRECTOR IS MY MAIN VOLUME.
Here's the problem:
I get a crackling sound in my tweeters at a medium/high volume, but only with loud recordings and bass heavy music.
When I turn the bass down in the Director, the crackling stops and I can turn the volume up a little more. Basically, the volume can be turned up without the crackling, to the extend that the bass is turned down.
Previously, I had the same equipment above with a MiniDSP and I did not have this issue...
Is the cord from the fiio to the dsp 75ohm?
Not sure. It's the same cord I head running from the Fiio X3 to the MiniDSP, before I swapped things out...
Are you thinking that the signal from the dap to the dsp is compromised or weak?
I know if the cord from the fiio to the dsp isnt 75ohm it will create noise issues. But that's all I know as of now.
By dap you mean fii0?
Blue Collar Audiophile
OK, the noise goes away when you turn the bass down. I know it's a longshot but might be worth seeing if it's a voltage issue. Have you put the tweeters on the Mosconi amp to see if the problem persists? Checked connections on amps and anywhere else there's a set screw to make sure they haven't got loose? I've had an amp do strange things because the set screw for the ground at the d-block got loose.
Yes, the fiio...
Interesting you brought it up... Recently, I have been hearing a random buzzing sound coming from the trunk... It goes away after a couple minutes, and I kept thinking it's one of my cameras, so I put it on the back burner.
Well... This morning the buzzing is louder, so I go back to my trunk and put my ear to the bass amp, and the buzzing is coming from the bass amp! :eek: Son a bitch, wtf is going on with my system! I didn't have time to do any more poking around, though...
Now I am wondering if the distortion issue is related to the mono amp?!?! I carefully worded this thread to not point the finger at a specific piece of equipment... Even though the tweeter crackling issue has been going on way before the mono amp buzzing issue, are they possibly related???
If they are related, how do the tweeters know that the mono amp has a buzzing issue when it's cold?!?! :confused: :mad:
One more thing I confirmed is this: the volume can be turned up without crackling to the exact dB that the bass is turned down on the Director - meaning, turn the bass down 3 dB when the tweeters start to crackle and you can turn the volume up 3 dB more before it starts to crackle.
Lastly, the crackling doesn't sound like the tweeters distorting from being pushed to hard, it sounds like a noise being introduced somewhere down the line.
I'm gonna poke around on the bass amp, and check connections as the next order of business...
Have you fiddled with gain structure in the processing and on the amps to see if something isn't playing nice? The Helix puts out 6v but the Zapco amps can only take up to 5v.
I did not know that... I have not messed with anything along those lines.
Keep in mind, that this noise issue is not present in hi-res normal recordings, only in the loud, bass heavy ones. With any other music I can turn the volume all the way up with zero noise or distortion.
I think priority is to fix this buzzing issue in the mono amp and seeing if that fixes both issues. The amp should definitely NOT be making this noise! Btw, the buzzing is not heard through the subs, it is coming from the amp itself...
Could be the hot recordings causing the amp inputs to get overloaded. Anything is possible in this hobby.
You got that right, brotha... Fuck. Lol
Would it be wrong of me to secretly hope that my bass amp is defective so I can give my GB12s a little more power from a new amp?!?! Lol :p
Discussion Starter #12
Have you tried unhooking your sub amp RCA's so it is "off" and leaving the bass up on the director like was mentioned in the other thread? Does it get the same results?
Discussion Starter #14
Yes, I did try that and got the same results as turning the bass down on the Director: less (or no) bass equals more volume without crackling.
So are you saying that you still had to turn the bass down on the director in order to turn the volume up..
Or
Are you saying that unhooking the amp meant that you could keep the bass the same on the director and turn the volume up all the way.
If the first, it is a sub/amp issue if you eliminate that and it goes away....
Discussion Starter #16
Or
Are you saying that unhooking the amp meant that you could keep the bass the same on the director and turn the volume up all the way>
Now that you mention it, I don't remember if I turned up the bass in the Director when I tested it with the bass amp unplugged.
Had it not been turned back up in the Director, then that test was a waste. I'll need to do that again, to make sure...
Discussion Starter #17
Now with this buzzing in the bass amp, I am starting to think that too...
How the bass amp is causing noise in the tweeters is beyond my elementary level of understanding. :rolleyes:
Are they connected to the same power/ground points? If so noise could easily travel between them. Same reason we get alternator whine and ground loop noise, etc.
That could actually be your ultimate issue is your power/ground points. The tweeter amp isn't having to draw as much current as the sub amp so it would be less noticeable in that amp.
Clipping almost always presents as a tweeter problem.
It sort of makes the other thread into, "solution interupus".
Use the same bad music and also a good music.
Maybe try:
1) unplug the RCAs from all but the tweeters amp inputs.
(Does the volume get louder before cracklings?)
2) Crank the amp's gain pots to max.
3) Test the bad music with ear phones
(Does the bad music sound bad there?
For all of ^these^ Note the know volume level where they start to sound bad.
The first (1) sort of eliminate errant amplifiers.
The second (2) suggests it is up front digital gain structure
The last one (3) points to bad files
Did Skizer walk you through any remote tuning yet?
Discussion Starter #20
Yes, same power and ground... I'd hate to think it's power or ground related. Those connections are solid. :eek:
1 - 20 of 165 Posts
