1 - 11 of 11 Posts
Ok due to the recent Ascendant deal I kinda went way overboard and bought an Avalanche 18" :oops:
Now I need a front stage that will be able to keep up with this behemoth.
I drive a 5-speed accord so I dont have much room for kicks (on the drivers side anyway). Because of this I would like to go with a two way setup. I could do a three way if I could get a mid less than 3.5" in diameter. I was thinking about going with some 8" XLS's in the doors (or maybe the RE XXX 6.5's??) and I would really love to try out some ribbon tweeters, not sure what ribbons would work best though. I am really open to any suggestions anyone might have.
thanks!
you could fit some large format tweet in the kicks like the dayton rs. no idea how high the peerless plays clean but i dont think it'll play high enough, so i would probably give the dayton ref 8's a try.
then yea... use the xls and how about some aura NS3-193-8A 3" full range drivers. run the peerless as high as they can cleanly and run the auras up from there with a compact tweet to match or all the way up to 20khz. i would probably keep it as a midrange and run an lpg tweet or something for the highs, say 5khz and up. that'll probably give you a flatter response as the auras have some weird action going on but thats not til 15khz or soemthing. anywyas that sounds like a great setup to me and i really cant think of a better 3" midrange for your case
npdang said:
What kind of budget are you looking at?
You may have trouble fitting a 3-way with ribbons and an 8" driver in your car...
My budget is pretty flexable. I would say I dont really want to spend any more than $400 for the speakers.
I have an older accord and the doors do have quite a bit of room. I will be able to get the 8's in if I space them out a bit. I just dont have a ton of room in the drivers side kick area for the mid and tweet.
thanks for your help 8)
DIYMA Founder
I'd probably recommend going with a Fountek neo 3 ribbon for $162pr., and a pair of Seas CA18RNX mid/bass drivers $106/pr. Keep it simple with a 2-way. It'd give you a strong, punchy mid and a very dynamic, detailed, smooth top end.
Or if you have to go with a 3-way, the Peerless XLS 8" for $126/pr + a pair of vifa mg10md's for $65, and then some lpg 25nfa tweeters $75. This would give you a good deal more mid/bass, but be a bit harder to setup and you'd lose the nice top end of the ribbons.
DIYMA Founder
I wouldn't do it... just doesn't sound as good playing that high although you may want to try it out and see for yourself. I find that some... ok most... people aren't quite as picky as I am about how things sound :)
Playing that high... you lose that sense of clarity and involvement that you get with a good midrange.
1 - 11 of 11 Posts
