Car is G35 sedan, 2003 ...
I pulled the carpet, which didn't fit properly, because when I did my deadening, I put a little too much overkill in. My goal was to pull the carpet, remove the overkill, then re-add some to get the carpet to fit right ....
I pulled the overkill and noticed that the bottom of it was wet. To my shock, I saw the Spectrum coating was bubbled up in the depressed portion of the floor pan closest to the door on the passenger side of the car. There was about 1/8 inch standing water. I peeled this away to find the Damplifier Pro was also wet with a thin layer of standing water. Ok, my first thought was a leak through the A/C condensation drain would runs on that side of the car, but I found the SAME issue on the drivers side ...
Anybody have any ideas what the heck is going on and how this could have happened?
