Hi! I am about to upgrade my "Outdoor rave" System. I will be using two 15" PA speakers, 600RMS, 8ohm. And I got two 155Ah industrial AGM batteries as power source.
The speakers:
HK Audio L5 115 F Linear 5
thomann.de/gb/hk_audio_l5_115_f_linear_5.htm
Now I need your help to choose an amp that would fit. I've done lots of research, but I'm still not 100% sure. The speakers will be connected parallell to hit 4 ohms. So I'm down to three options:
A 2ch, class D amp, which I will bridge to 4ohm.
A monoblock, also class D, but with the power to drive the speakers at 4ohm.
Or just get 2 monoblocks that are bridgeable.
Right now im Looking at:
Precision Power PPI P600.2
sonicelectronix.com/item_38336_Precision-Power-PPI-P600.2.html
Will this be able to give enough power for the speakers?
or,
Stetsom 2k5eq
stetsom.com.br/en/produto/2k5-eq-2-ohms
or,
Two Precision Power PPI P1000.1 bridged (((IS THIS FULL RANGE?)))
sonicelectronix.com/item_38335_Precision-Power-PPI-P1000.1.html
I live in europe, if that matters. Do you have any other amps that would be better? Max $700.
/ Wirne
The speakers:
or,
Stetsom 2k5eq
or,
/ Wirne
