I'm hooking up a sub to my existing system, so i'm running a new line from the terminal on the battery (there's one spare).
This will run through a fuse right there, and then onto the Amp.
The sub is a Memphis 15-SC12D4, a 500w RMS (1000 Peak?) Shallow Subwoofer. It'll be in a sealed box.
Running it, will be an Alpine PDX 1.600 Monoblock Class D 600W Amplifier.
On this amp, it has 4x 20 Amp fuses. (PDF here)
So would I be correct in assuming I need an 80 Amp fuse if this is the only thing i'm going to run off this line?
Also you reckon 4 gauge or 8 gauge wire connecting it would be the go?
Thanks
Thanks
