hi, new here so open for suggestions....
ive been running high end audio for a while now, and have finally decided to rewire my power cables properly.
over the years ive added amp, then sub, then amp etc etc, so i have 4+ powered cables from battery, plus remote cables (switched) for each device,(probably not the best idea) but have invested in some high quality distribution blocks with fuses, 4 gauge cable, earth mounting/distribution block, lots of gear to make it safe.... the big question is what fuse/circuit breaker should i use near battery? how do i work out what amp fuse to use?
there is: 2000w vibe black box amp,
2000w 15'' vibe black air
1500w vibe evo I amp
plus extras when i need them, all of which is running through a single cable from battery to distro, so needs high power and high protection. any help/advice needed asap, as im booking time off work to do install.
cheers
cheers
