We are gonna need more info. From what you are telling me, I can assume the amp is a 2 channel and will be driving a pair of mids and tweeters.
If you use the amps xover and set it at 1.5khz then that passive xover will be useless cause anything BELOW that amps over setting will be unheard. Even the mids will play 1.5hkz. So, if you want to use a 2 channel amp with a pair of speakers you will have to do 2 things, ONE, use a passive crossover that cutes off the tweeters at 1.5khz or whatever high pass frequency the tweeters need. And usually the passives will cut of a mid so the mids stop playing anything higher than the cutoff of the tweeter. TWO you will then have to use your amps xover to cut off the mids so they dont play bass. Somewhere around 120hz.
If your amp has a lowpass cutoff that goes really high, which is unusual, you can actually use the amps xover to cut the mids off at 1.5khz so it dont play any highs. ANd then use the passsive xover on the tweeters so they wont play anything lower than 1.5khz.
