1 - 20 of 20 Posts
Fuse for the wire, not the amp. What AWG are you using, and how long is the run?
That would be true if he's adding a fuse for the power wire. But he said "in the amp", suggesting that he's looking to replace the amp's internal fuse. And if he doesn't know the amperage, that suggests the previous fuse is missing.
Anyway, Google is a wonderful thing. A simple search indicates that the amp uses a 40A fuse. Seems a little small for a "2500W" amp:rolleyes: Obviously it's way overrated!
A 40A fuse suggests tat it draws less than 40A, which sort of answers questions on what size alternated that 2500W amp requires.
Yeah, if he's missing the fuses on the amp, you're right.
The amp is only rated for 650 watts at 2 ohms so it won't need a big fuse.
Assumptions:
  • The stated specs are accurate (650 W RMS)
  • 13.8 volts
  • The amp is 60% efficient
You will draw almost 80 amperes of current.
But, we know that it has 50 amperes of fusing, so my assumptions are wrong. Perhaps you have 80% efficiency and 14.4 volts? That will draw 57 amperes of current. More than likely the amp is only good for 400 watts. After making that prediction I am going to watch the video posted above.
Edit: From the video posted above: 631 RMS certified. Must be more efficient than I thought.
Assumptions:
  • 13.8 volts
Are class D amps 80% efficient and A/B 60%?
Most amps have the lowest efficiency at the lowest output, so for instance a Class-A may draw 100w at zero volume... aka "quiescent current (power) draw".
Class-AB have a much lower quiescent draw.
What the efficiency is flat out I am not sure... but a lot of people do not run their equipment flat out.
OK well they all draw amperage and output watts so ...
(So) he should probably use the fuse that manufacturer recommends inside the amp, ignoring any sidetracking math lessons about efficiency.
Or do you mean how do we find out what the efficiency of an amplifier is?
The only solid way I know how to do the later is by measuring RMS current going into the amp, but those clamp amperage meters are not in everyone's tool kit and they are not cheap.
It is going to vary by amp manufacturer. Willision Audio Labs on YouTube will put a clamp on the power wire and calculate efficiency on MOST of the amplifers that he tests. The highest I have ever seen was 80% on an audio control amplifier. A lot of the cheap brands are not terrible efficient.
Most amps you have to run a tone full bore to use the full amp rating. Though I know some amps used to run tons of fuses for looks. I have a 100A 5ga kit running 1kw with 2 class D and use a 50 or 60A fuse at the battery and never had an issue. But I don't listen to bass tones at full volume, maybe dubstep has been run on there loud though. But only a 500w on the subs. I don't get any voltage drop at the amps. If you want a treat put a clamp on meter on your power wire and see what you get. It is very low until you get to high volumes or crank bass tones.
1 - 20 of 20 Posts
