1 - 9 of 9 Posts
Trying to decide here for myself.
Which one could be louder? :
8 8" RE Audio subs with 125 watts to each sub in a common chambered sealed enclosure
or
1 18" RE Audio sub with 1500 watts in a vented enclosure
it would depend on the box, the car, the amps and speakers. but uhm my guess is you could do more with 8 8"s
Box after displacement 2.66 cu ft internal on the 8's
Box after displacement 5.44 cu ft internal on the 18
Speakers:
RE Audio REx8 dual 4ohm (8) rated at 175 rms
RE Audio SX18 dual 2ohm (1) rated at 1200 rms
Amp:
RE Audio DTS1500.1 if I run the 8's
RE Audio XTX3000.1 if I run the 18
car:
2011 VW Golf 2dr
Mostly price. I can get one SX18 for about the same price as 8 re8's. Everything else i have looked at would either not handle the power or would require way too much power. Plus i have a very small car and want to keep the enclosure no bigger than 38w x 20h x 18.5d
8 RE Audio 8's are $316 shipped and I can use the amp I already own RE Audio DTS1500.1
1 RE Audio SX18 is $273 shipped have to buy RE Audio XTX3000.1 for $230 shipped so $503
2 Sundown SA12 is $390 shipped have to buy RE Audio XTX3000.1 for $230 shipped so $620
Multiple motors means less power compression (heat induced resistance increase)
Remember that your sub is also a space heater. Single motor on 1500 watts or 8 motors sharing that 1500 watts...
NOW, as I am going to lunch, determine what has more SD the eight 8" subs or single 18.
That alone will help determine output no other factors determined.
1 - 9 of 9 Posts
