1 - 3 of 3 Posts
check out the daichi brand also the founteck brand and peerless also sum of the concentric ring tweeters from vifa and scan and for the hell of if fs on the revelator is 500hz and its(1" D2905-990000) and its a sweet tweet the scanspeak revelator and the HDS peerless 1" tweet its fs is about 700ish hz (code 810921) and it is a nice soft dome tweeter and the vifa duel concentric both sheilded and non sheilded at 600hz ish and about 700hz (XT25TG30-04) and sheilded is (XT25BG60-04)
the sb accoustics 1" textile dome (SB25STC-C000-4) AND THE daichi is 1400hz and is (DTSC25 OR DTSR25) there is also a horn loaded version in a 1" dome with an fs of 1khz and it is (HTW25)
me personally i like the revelotor and the HDS from peerless and denmark but im not sure if they have the right ohms your after hope this give you a couple more options to look at they range from around 16bux up to about 4-500 bux and thats sumtimes is each not a pair
Ren
xMplar
Sounds like some good options gonna check those out. Anything else? if it helps im Really looking for a very detailed tweeter at no more than 60 for the pair. Not really concerned with materials since placement and aiming will mainly affect "harshness" and what not
1 - 3 of 3 Posts
