Would the person that originally set it up for you have a copy of the tune saved? I wish I could help you. The only person I know to recommend is Nick at Vanguard Automotive. I’m sure he has a long list of folks already scheduled though.
Im not sure, they set a few things but said we would refine over the phone next week. It’s soundsgoodstereo who built It. They’ve been fantastic, I just feel like a moron messing with it when I should have waited.Would the person that originally set it up for you have a copy of the tune saved?
This is the setupYour best bet would be to just wait for the shop to tune it for you, I can guide you through the ps8 software, but you’ll have to know everything about how the system is setup.
^^^This^^^SGS should be able to send you the file again that you can load onto your DSP.
I’ll reach out to them for sure, here’s my big question though. If SGS tuned amps physically and dropped the partial tune on the DSP… why is it when I reset it on accident, the volume is extremely week out of the system? I hear mainly tweeters and maybe mid bass very very faintly. Am I wrong to assume with DSP reset I’m defaulting to basically whatever the amps are tuned to?^^^This^^^
Barring that, here's a link to the CAT-BUG (tuning guide):
Introdicing CAT-BUG. Car Audio Tuning - Beginners Ultimate Guide. I tried to make it as silly as possiblle so that no one would take it seriously😂 Especially proffesionals or experienced people. I had this project in the making quite for a while now. I made a lot of mistakes while making YT...www.diymobileaudio.com
Good luck!![]()
I could be totally wrong but all that will be controlled with the tune they loaded into the DSP.I’ll reach out to them for sure, here’s my big question though. If SGS tuned amps physically and dropped the partial tune on the DSP… why is it when I reset it on accident, the volume is extremely week out of the system? I hear mainly tweeters and maybe mid bass very very faintly. Am I wrong to assume with DSP reset I’m defaulting to basically whatever the amps are tuned to?
Unless you changed the amp settings, the only thing that has changed is the DSP settings, in which case restoring those settings should do the trick. Perhaps I'm missing something...?I’ll reach out to them for sure, here’s my big question though. If SGS tuned amps physically and dropped the partial tune on the DSP… why is it when I reset it on accident, the volume is extremely week out of the system? I hear mainly tweeters and maybe mid bass very very faintly. Am I wrong to assume with DSP reset I’m defaulting to basically whatever the amps are tuned to?
It was much louder, but still no where near how my last system sounded (same gear, less powerful amps) so I believe they left it tamed until I could remotely tweak it with them.I could be totally wrong but all that will be controlled with the tune they loaded into the DSP.
You may have mentioned but did you have good volume before you messed with the DSP's settings? As in as soon as the system was installed straight from sounds good stereo?
Im just confused with the software… what would cause no sub and barely any mid bass? It’s obviously advanced software. Even after reading and watching videos I don’t even know where to begin. I’m probably best off waiting until Wednesday when I get on the phone with them.Unless you changed the amp settings, the only thing that has changed is the DSP settings, in which case restoring those settings should do the trick. Perhaps I'm missing something...?
Chances are they set it that way on purpose so people don’t screw anything up before they can finish the tune. Some people just have to touch things they shouldn’t…as you learned. And at this point if you wiped the tune completely don’t even turn it on…you’ll likely kill your tweeters in short order.Im just confused with the software… what would cause no sub and barely any mid bass? It’s obviously advanced software. Even after reading and watching videos I don’t even know where to begin. I’m probably best off waiting until Wednesday when I get on the phone with them.
Fair enough. I’ll add it to the lessons learned.Chances are they set it that way on purpose so people don’t screw anything up before they can finish the tune. Some people just have to touch things they shouldn’t…as you learned. And at this point if you wiped the tune completely don’t even turn it on…you’ll likely kill your tweeters in short order.
Contact SGS and have them send you their base tune to reload into the processor then leave it alone until you get back with them.
